1Soldering the main components
Layout your sockets on the pcb and solder.
2Connecting the wires
ZX EEPROM
Memrq -> oe
A0-A13 -> A0-A13
D0-D7 -> D0-D7
5v/gnd -> 5v/gnd
Pull the eeprom we and a14 high.
Connect the the zx a14 and a15 to pin 1 and 2 of the 74ls32 then pin 3 to ce pin of the eeprom. Also Connect the 74ls32 to 5v and gnd.
Pull zx memrq high.
This will allow you to play burnt eeproms on the zx spectrum.
3Toggling the interface
Using a double throw switch connect similar to below
X -------- 5v
Memrq---74ls32 pin 5
5v---------gnd
Connect pin 3 to pin 4 of 74ls32.
Finally connect pin 6 of the 74ls32 to the ce pin of the eeprom.
Now you can toggle between zx spectrum and the new eeprom interface!
