Laser-cut plywood box
A project log for Simon game with ATtiny13
Full-featured clone of a famous “Simon” game for training your visual and acoustic memory. Electronic kit simple enough for beginners.
VojtakVojtak 02/19/2017 at 00:380 Comments
The box for Simon game is designed to be laser cut from 3.2 mm thick plywood.
Bottom wall is removable and fixed by four M3 × 16 mm countersink screws.
The M3 nuts are set in the top wall which is glued to four side walls.
Four small L-shaped parts should be glued to the inner corners of the box (to reinforce the plywood under the nuts).
Small cross-shaped parts should be glued to the bottom wall under four button switches.
Files for laser cutter are in the download section.
