Fresnel zone antenna (PCB)
Antenna for WiFi and Bluetooth based on shading of the second Fresnel zone (Fresnel diffraction).
Not tested with a real WiFi signal, only spectrum analyzer results so far.
Description and requirements
  • Initially, the task was to be able to use open Wi-Fi networks that are placed far away and have weak signal levels.
  • The antenna either should have been small or portable or could be assembled/disassembled.
  • F=2.45 GHz but possibly also F=5..6 GHz. Wi-Fi and Bluetooth should be covered.
  • The receiver should not be placed so far away from the antenna for practical use. Focus distance r=50 cm for 2.45 GHz. r=120 cm for 5.9 GHz.
  • The diameter of the antenna should be no more than 70cm for practical use. D=70cm.
  • We assume that the source is placed at an infinite distance.
  • The antenna design is a metal ring with an external radius = of 0.35m and an internal radius = of 0.247m.
  • Not tested with a real Wi-Fi signal yet, only spectrum analyzer result so far.
  • During simulation, it found that for focus distance f=50 cm and diameter of antenna D=70cm, the optimal gain is achieved using only shielding (shading) second Fresnel zone.
  • Thus, all zones are open except the second one.
  • Such configuration can give an amplitude gain 3.0 (9.5 dB).
Vector diagram for gain calculation:
Calculation
For 2.45 Ghz
For 5.5GHz
Simulation
Setup
Simulation setup in optiFDTD:
Simulation setup in optiFDTD with plane wave source:
Results – plane incident wave
F=2.45GHz
Result at receiver:
Result along the Z-axis:
Field magnitude along the Z-axis:
Peak position around f=46mm (96mm-50mm):
Conclusion
  • A gain of around 2.8 (9.0 dB) can be expected for F=2.45GHz.
  • For F=2.45GHz focus distance f=46 mm where the field is maximum.
F=2.45GHz with the presence of a tablet pc or smartphone at the focus
Setup with the presence of a tablet pc at the focus:
Simulation with the presence of a smartphone or tablet pc at the focus:
Conclusion
  • Seems like presence of smartphone/tablet pc does not affect the gain a lot.
  • Some standing waves can be seen at the antenna of the receiver but the field strength is still high.
  • Should be tested with the spectrum analyzer.
F=5.9 GHz
Conclusion
  • A gain of around 2.8 (9.0 dB) can be expected for F=5.9GHz.
  • For F=5.9 GHz focus distance f=120+ mm where the field is maximum.
Results – simulation with the point source at the far field
Setup
Setup with points source:
F=2.45 Ghz
Comparison at a far distance and point source simulation:
Far-field comparison without and with antenna:
Conclusion
  • A gain of around 2.8 (9.0 dB) can also be seen with far-field simulation.
  • It also proves that the antenna will work in both modes: receiver and transmitter. It is also theoretically proved by the reciprocity principle.
PCB design
  • Thus, the antenna design is a metal ring with an external radius = 0.35m and an internal radius = 0.247m.
  • For portability, the ring is split into 8 pieces, so the antenna can be assembled and disassembled.
  • PCB design has only one metal layer (TOP).
PCB design:
Assembly
  • Parts should be connected using interleaving – one part normal, one part upside down,
  • In this case, the metal layers (TOP) touch each other directly.
  • Such a connection also helps to compensate for the curvature of each PCB.
Two parts connection:
Antenna assembled:
Test results
Setup
  • Beacon with spread spectrum as a source at the distance of about 40m.
  • Loop H near field probe as a receiver.
  • FLP1003 spectrum analyzer.
Measurement at receiver point:
Measurement results
  • The following pictures show difference with and without the antenna presented.
  • Case with antenna shows a higher signal level (5...10...
zones_calc.ods
Calculation of Fresnel zones dimensions
spreadsheet - 11.68 kB - 02/13/2023 at 10:41
Download
OptiFDTD.zip
Simulation in OptiFDTD
x-zip-compressed - 51.51 kB - 02/11/2023 at 20:18
Download
gerber_fz.zip
Gerber files
x-zip-compressed - 129.26 kB - 02/11/2023 at 20:17
Download
  • 1
    Step 1
    Assembly
View all instructions
