While revisiting key handler handleKeyScanCode_EE37 and back annotating scan codes into the code, I wind up with this:
EE37 handleKeyScanCode_EE37:
EE37 13 63 01 04 brclr bCloverKeyDown_63 1 noclover_EE3F ; true if 'clover key down'
EE3B 12 61 01 C9 brset bAltKeyDown_61 1 optionclover_EE08 ; true if 'alt/option key down'
EE3F noclover_EE3F:
EE3F 13 64 01 02 brclr bShiftKeyDown_64 1 cont_EE45 ; true if 'shift key down'
EE43 8A 80 oraa #$80 ; set high bit in base scan code to mark as shifted
EE45 cont_EE45:
EE45 97 70 staa scratch_70 ; save the scan code for later
EE47 81 56 cmpa #$56 ; 'Clear File' scan code
EE49 27 DD beq doDeleteFile_EE28
EE4B 81 2B cmpa #$2B ; 'Delete' scan code
EE4D 27 28 beq doDeleteChar_EE77 ; delete a char in file?
EE4F 81 35 cmpa #$35 ; 'arrow Left' scan code
EE51 27 2A beq doLeft_EE7D
EE53 81 34 cmpa #$34 ; 'arrow Right' scan code
EE55 27 36 beq doRight_EE8D
EE57 81 37 cmpa #$37 ; 'arrow Up' scan code
EE59 27 40 beq doUp_EE9B
EE5B 81 15 cmpa #$15 ; 'arrow Down' scan code
EE5D 27 4A beq doDown_EEA9
EE5F 81 66 cmpa #$66 ; 'Home' scan code
EE61 27 54 beq doHome_EEB7
EE63 81 75 cmpa #$75 ; 'End' scan code
EE65 27 55 beq doEnd_EEBC
EE67 81 2D cmpa #$2D ; 'Caps lock' scan code
EE69 27 56 beq toggleCapLock_EEC1
EE6B 7E EF 67 jmp loc_EF67
EE6E loc_EE6E:
EE6E 7E EE C9 jmp normalChar_EEC9
EE71 BD F0 13 jsr sub_F013 ; XXX prepare to send (flags and prompt)
EE74 7E EE E0 jmp leave_EEE0
...Now things are much clearer! The various 'do XXX' locations are usual small, e.g.:
EEB7 doHome_EEB7:
EEB7 BD F1 6B jsr sub_F16B
EEBA 20 1E bra sub_EEDASo it is reasonable that sub_F16B does whatever the 'Home' key does (probably move the insert point to the first char position and update the display as appropriate).
Others have modifiers:
EEA9 doDown_EEA9:
EEA9 13 63 01 05 brclr bCloverKeyDown_63 1 doDownOnce_EEB2 ; true if 'clover key down'
EEAD BD EF 3D jsr sub_EF3D ; XXX clover-down whacks F0DF handler four times
EEB0 20 28 bra sub_EEDA
EEB2 doDownOnce_EEB2:
EEB2 BD F0 DF jsr sub_F0DF ; XXX down arrow handler
EEB5 20 23 bra sub_EEDASo it seems that in this case that the cloverleaf modifier would go down a 'page' (of 4 LCD lines), whereas the unmodified version moves down a line.
In all these mini-handlers, there is a jump to sub_EEDA, which is brief:
EEDA sub_EEDA:
EEDA BD F3 74 jsr sub_F374
EEDD BD F2 56 jsr sub_F256
EEE0 leave_EEE0:
EEE0 39 rtsThis routine has a lot (22) references throughout the code. Taking a quick peek at sub_F374, it starts with a call to clearHomeLCD_F618, fiddles with file related stuff, sends chars to the screen, and then ends with the 'caps lock indicator' mentioned a couple days ago. So this feels like maybe the 'update screen for file state' function. One sub-method was interesting:
F62D sub_F62D:
F62D 81 09 cmpa #9 ; less than TAB?
F62F 2D 19 blt bogoChar_F64A
F631 85 80 bita #$80 ; high ASCII?
F633 26 15 bne bogoChar_F64A
F635 81 5C cmpa #'\' ; ascii backslash looks like Yen on LCD, so translate
F637 27 15 beq xlatbackslash_F64E
F639 81 7E cmpa #'~' ; ascii tilde looks like right arrow on LCD, so translate
F63B 27 15 beq xlattildeswinton_F652
F63D 81 0D cmpa #$D
F63F 27 15 beq xlatcr_F656
F641 81 09 cmpa #9
F643 27 15 beq xlattab_F65A
F645 16 tab
F646 loc_F646:
F646 BD F6 74 jsr sendLCDbyteB_F674 ; send byte in B to LCD (w/ctrl as per 0x5b)
F649 39 rts
F64A bogoChar_F64A:
F64A C6 3F ldab #'?' ; junk character maps to '?'
F64C 20 F8 bra loc_F646
F64E xlatbackslash_F64E:
F64E C6 8F ldab #$8F ; LCD backslash char
F650 20 F4 bra loc_F646
F652 xlattildeswinton_F652:
F652 C6 F3 ldab #$F3 ; LCD infinity is an approximation of tilde
F654 20 F0 bra loc_F646
F656 xlatcr_F656:
F656 C6 7F ldab #$7F ; LCD left arrow indicates hard CR
F658 20 EC bra loc_F646
F65A xlattab_F65A:
F65A C6 7E ldab #$7E ; LCD right arrow indicates TAB
F65C 20 E8 bra loc_F646This clearly translates file ASCII into LCD characters. Most of the LCD follows ASCII, but a few symbol positions have different glyphs, so this fixes those up. Aside from understanding the code, the context is useful because it seems to suggest that sub_EEDA is in fact 'update display for current file'. The first routine sub_F374 being 'do the showing file part'. The second routine sub_F256 is briefer:
F256 sub_F256:
F256 86 28 ldaa #40 ; (char per line)
F258 D6 6C ldab word_6B+1 ; XXX 0x0101 upon file cleared; row, col? 1-relative
F25A 5A decb
F25B 3D mul
F25C DB 6B addb word_6B ; XXX 0x0101 upon file cleared; row, col? 1-relative
F25E 5A decb
F25F 14 5B 01 bset lcdCtlLineState_5B 1 ; set OC2,OC1 to 11; 'set cursor address'
F262 14 5B 02 bset lcdCtlLineState_5B 2 ; LCD control lines state in b1 = IOC2, b0 = IOC1
F265 BD F6 74 jsr sendLCDbyteB_F674 ; send byte in B to LCD (w/ctrl as per 0x5b)
F268 15 5B 01 bclr lcdCtlLineState_5B 1 ; return OC2,1 to 10; 'data'
F26B 39 rtsIt fiddles with the word_6B and does a set cursor address, so this seems to suggest word_6B is in fact two bytes and they are the row/col (1-relative) screen position of the cursor. This will be useful to back annotate into the various other routines that use/manipulate these locations.
So, some more mysteries solved. Time to comment and propagate info throughout.
ziggurat29
Whoa, jump after jump after jump!
Seems like a nightmare to backtrace!
Also, yet another character-encoding translation! Hah, four now?
