General Laptop Water Cooling Bottom Support
Easy use, Easy build up, cooling effect rapidly !
Public Chat
General Laptop water cooling bottom support.
As the heat density of chip grow fast, most of gaming laptop will hit thermal wall when thermal grease deteriorated. It a necessary thermal engineering problem need to be solve. This prototype bottom water cooling support may can fix this issue.
Construction
Using sheet metal with huge blank area to fit water cooler plying-up heat generate area. Inside guide rail system make water cooler fixed more easier.
BOM(Bill of Metal)
sheet metal structural component
TH15 rail *2
water cooler fixed component(3D Print)
E/MK1 rail fixed part
M4 screw *6
M4 nut *6
M4 gasket*6
120 PC water cooler
120mm fan
PWM shift controller
few piece buffer
THIS WORK IS LICENSED UNDER CC BY-NC-SA 4.0 LICENSE
x-zip-compressed - 58.75 kB - 03/10/2023 at 18:25
Download
BS_sheet_metal_V1.SLDPRT
bottom support sheet metal
sldprt - 505.51 kB - 02/16/2023 at 10:07
Download
