a RV1126 Board
A mini RV1126 Board, trying to put it inside a full size mini-PCIe form factor.
I want it to be a standalone board, it will be a complete system after user plugs in battery , camera and optional display.
Finally I think I got my understanding to length calculation in net inspector and length matching tool, and I should rely on the result of length matching tool.I need to do length matching to other groups
Will continue to do length matching as next step
I tried but mini PCIe spec is too small for it.
So I decided to change the board spec to 96boards SoM instead.I will have more area to put all components
JLC CalculationNew Stack upUpdated Net ClassesUpdated Custom Rules
Fan out SoC pins ( by hand )
Updated Design Rules:
I have set up basic schematic for minimum system:
I have setup PCB Physical Stackup (JLC061011-2116):
View all 6 project logs
WingTechCorner
Frank
Michael Welling
Lukasz
Yes, delete it Cancel
You are about to report the project "Leaf rv1126", please tell us the reason.
