[Project Log 28012023]
A project log for Building a equipment to help ambulances
Building a equipment to help ambulances run through intersections.
TRAN.VINH.QUANGTRAN.VINH.QUANG 03/20/2023 at 15:450 Comments
The project has finished setting up the gcode file to process the IoT module test circuit board for the device.
Continue to update...
