Last Day - Software
04/16/2023 at 12:26 • 0 commentsMake software compatible with my other project the PiBoy best performance on botth with Manjaro ARM.
Day 5
04/01/2023 at 11:43 • 0 commentsConstruct frame parts, better keyboard and print everything.
Print keyboard sticker and laminate them.
Now i will make some testing and optimise the software.
I think Phosh is a great desktop for this kind of PC
Day 4
04/01/2023 at 11:38 • 0 commentsI also installed a USB soundcard for better Sound and Mic support, a 2W Speaker and switches for secureity to turn of the Mic.
Everything should work now.
Day 3
04/01/2023 at 11:34 • 0 commentsSolder LED for Keyboardbacklight and 3D Print keyboard and Frontframe:
Day 2
04/01/2023 at 11:31 • 0 commentsDesolder all unused big parts like USB, RJ54 from the Raspberry Pi and cut out the baseboard.
Install Raspberry Pi, PiSugar and Hyperpixel Display:
Day 1
04/01/2023 at 11:27 • 0 commentsSoldering the Keys to the baseboard:
Each key has is own diode.
The diodes using the space between the Keys.
At the Back side the columns was connected with thin coper wire:
The QMK Layout is this:
Install the Trackpoint board at the backside:
Spider Jerusalem
