Mild steel is fun, but HSS means business.
The settings used where too weak for HSS and I stopped the process. It would have taken too long and currently it is not possible to change the settings at realtime except for the Amps on the PSU.
Next time I will use a little more aggressive settings. But damn nice.
The GCode was created with the customized FreeCAD GRBL post processor.
