G-EDM EVO2 meets PicoEDM wire extension
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 03/24/2024 at 02:090 Comments
The G-EDM Tower was initially designed as a single axis sinker EDM and now with multi axis support it is time to refresh it.
A little Gantry CNC router using the PicoEDM wire extension. Evolution never stops.
For more details about the PicoEDM see: https://github.com/alextreseder/picoEDM
The G-EDM EVO2 is a medium duty high gantry router design that takes care of future upgrades for normal milling operation.
A RO-Filter system is mounted on the back of the machine and the water hoses will be routed through the profile into the tank to make them almost invisible.
