Let's go outside to find the sun - first test
A project log for mysoltrk - a solar tracker, reinvented
A different approach for a solar tracker, alternative movements, to be installed on the outside, to optimize the efficiency of solar panels
fulvioFulvio 07/03/2023 at 18:410 Comments
After completing the assembly, we had to wait for a sunny day.
Here is the result of the test with prototype #2 using the code showed on this log:
At this point we can consider the hardware is working as expected and we can concentrate on the software implementation of the solar tracker.
Stay tuned!
