The final report
A project log for mysoltrk - a solar tracker, reinvented
A different approach for a solar tracker, alternative movements, to be installed on the outside, to optimize the efficiency of solar panels
fulvioFulvio 09/29/2023 at 14:390 Comments
Hello everyone!!!
Finally we can share the latest tests with the new solar panels.
Thanks to the PCB board, we are able to quickly build the mysoltrk devices.
The outdoor tests focused on the strength of the actuators and reasonable weight/size of the panels to be used.
In addition, the tests showed that the design can be put outdoors without worrying about weathering.
Here our video published for the contest. We hope you like it.
