ESPClicker
ESPClicker is a simple project that will allow you to convert various household appliances into IoT
dmDM
Espclicker is a small device that you can use to integrate not IoT devices into your smart home setup, It connects directly to the push buttons of the device, which you want to control, and then simulates pressing them. You can simulate button clicks, hold time, and multiple clicks. Espclicker has three small relays One of which can be configured as normally open or normally closed. also, it has a contactless AC power detector and two “low-side” switches, for connecting additional power relays, so you can connect external relays with different coil ratings, for controlling the big load.
https://youtu.be/Gc4yCd9yvuE
All files are available on GitHub: https://github.com/PricelessToolkit/ESPClicker
Technical Specifications
  • 4 Layer PCB
  • WiFi Module ESP8266 ESP-12F
  • 3x Built-in signal relays ( Control PINS: R1-GPIO4, R2-GPIO5, R3-GPIO12 ) "R1 can be configured as normally open or normally closed" MAX LOAD 500mA 24V
  • 2x Low-Side Switch "ULM2003" ( Control PINS: LS1-GPIO14, LS2-GPIO15 ) MAX LOAD 300mA
  • 1x ADC Pin "1V Max"
  • 1x ACS Pin "AC Power Detector" (Input Pin GPIO13)
  • Requires 5-12V 500mA power supply
  • 3 × CL31A226KAHNNNE 1206 22uF
  • 3 × CC0603KRX7R9BB104 0603 100nf
  • 9 × RC0603JR-0710KL 0603 10K
  • 1 × 1N4148WS SOD-323
  • 1 × TPSPX3819M5-L-3-3
View all 14 components
  • 1
    Step 1
View all instructions
