dollibodi.stl3D model of the body of the dino !Standard Tesselated Geometry - 1.91 MB - 06/13/2023 at 15:12 |
dolly foot.stl3D model of the dino footStandard Tesselated Geometry - 314.93 kB - 06/13/2023 at 14:24 |
Dolly thigh.stl3D model of the dino tighStandard Tesselated Geometry - 209.46 kB - 06/13/2023 at 14:23 |
dollytibia.stl3D model of the dino shinStandard Tesselated Geometry - 127.82 kB - 06/13/2023 at 14:17 |
Doli_tail (1).stl3D model of the dino tailStandard Tesselated Geometry - 1.50 MB - 06/13/2023 at 14:16 |
box_1.svgThe laser cuttable box in which we put the gearssvg+xml - 4.09 kB - 06/13/2023 at 14:16 |
inside_walls__gears.svgThe laser cuttable gears and wall they are attached tosvg+xml - 1.31 MB - 06/13/2023 at 14:16 |
bevel (2).stl3D model of the bevel gearStandard Tesselated Geometry - 117.46 kB - 06/13/2023 at 14:16 |
Cam (1).stl3D model of the cam gearStandard Tesselated Geometry - 43.25 kB - 06/13/2023 at 14:16 |
dolly_neck_and_head (1).stl3D model of the dino head an neck ( articulated)Standard Tesselated Geometry - 3.15 MB - 06/13/2023 at 14:15 |
The dolly process.pdfPDF slides !! (explanations)Adobe Portable Document Format - 2.53 MB - 06/13/2023 at 12:43 |
