CETBRK - Cheap Easy-to-build Robotic Kit
A robotic kit with low part count and easy to build, for teaching electronics and robotics.
Public Chat
The project is being developed to bring technological knowledge to the masses.
It is being designed to have a low part count, including parts easily found in hardware stores, like the sewer o'rings used as tracks.
It can use any acessible board as brain, like the well known Arduino Uno, the Digispark Attiny85 board, ESP8266, ESP32 or any other microcontroller board available nearby.
It can be assembled with almost no tools, once it uses cable ties in the jointing points. For motion, it can use the famous SG90 Micro Servo, adapted for continuous rotation or the original 360º continuous rotation SG90.
For power feeding, it can use 3.7V batteries, included those found in old cellphones. The old cellphones could be reused for charging the bateries, or the kit can include easely found 3.7V batteries and its respective charging boards.
The kit is usefull for teaching electronics, programming, mecatronics and even basics of web development(if including ESP8266/ESP32 boards).
Assembled Kit
JPEG Image - 3.51 MB - 04/19/2023 at 19:47
Preview
Download
{b81773b2-8c27-4425-bbad-426d458c9400}.mov
Bluetooth Controlled Robot video demo
quicktime - 3.76 MB - 04/19/2023 at 19:28
Download
