NEAToBOARD ESP32
An ESP32 based, Arduino compatible, educational reference board and DIY soldering kit.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
NEAToBOARD ESP32 soldering kit is a board that I wished was available when I first started learning and tinkering with Arduino compatible microcontrollers.
I designed it to be breadboard friendly, and optimized the space available for connections.
The labels are clearly readable both front and back.
The ESP32 pins are exposed in a logically arranged sections.
Breakouts provided for JTAG, USB and programming interfaces.
Uses larger 805 sized SMD components and soldering pads.
Comes with built-in breakaway example boards demonstrating buttons, LEDs and basic communication interfaces (SPI, I2C, Qwiik)
Includes plenty of spare parts, 2 PCBs and reusable components tray in either black or white color.
This is a work and progress and I am working on lessons covering the functionality of the board and the built-in PCBs and programming. I also intend to make some video tutorials and demonstrations.
