ot-HS
10-year battery life OpenThread temp/RH sensor
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is a temperature/humidity sensor designed for operation around saturation RH, to provide accurate data to HVAC systems. To facilitate accurate readings, the sensor runs a simple algorithm to run a heater and compensate for creep errors. The sensor communicates using OpenThread and periodically sends data over CoAP. It also registers a generic IP advertisement service with the "nearest" SRP server.
https://github.com/edward62740/ot-HS
