Arduino_Joystick_Mouse_Enclosure.stlEnclosure for a joystick mouse made from an Arduino Pro Micro, joystick module, and tac switch. Margins are tight, so recommend lightly filing the inner tracks of the enclosure, and/or the rough sides of the boards themselves to slide them in easier. The solder points on the Arduino also need to be low profile and facing inward, and the excess solder under the joystick board needs to be clipped off.Standard Tesselated Geometry - 13.37 kB - 05/24/2023 at 16:20 |
