1Assembling the Hardware
Solder the wires (or JST connectors) to the Pi Picos. The red wire should go to VBUS, white one to GND, and green one to GP28 (pins 40, 38, 34 respectively).
For the moss, just place the LED matrix on a surface and connect it to one of the Picos. Optionally add diffuser.
The tree is a little bit more complicated, but the general idea is to have the LED rings connected starting from the biggest one to the smallest one. We used a paper cup as a base for the 35LED ring, pulled some cardboard through the center, and then attached the rest.
Flash the Raspberry Pi Picos with CircuitPython.
2Programming the Raspberry Pi Pico
The code for the tree is in the
drzewosubdirectory.The code for the moss is in the
mechsubdirectory.Drzewo and mech are Polish for tree and moss.
The code is written in CircuitPython and uses some additional libraries. The easiest way to install them is with circup
For the moss controller run:
circup install -r mech/requirements.txt
For the tree controller run:
circup install -r tree/requirements.txt
After that, install smolmidi by copying it to the
libdirectory on your Picos.Finally, copy the
code.pyfrom both subdirectories onto the respective Picos. -
3Installing Ableton
This project requires you to have Ableton installed on your machine. Free 90-day trial is available that lets you play and experiment, but you won't be able to save any changes to your project.
On MacOS, you can get it with
brew install ableton-live-standard.In Ableton Live (Standard or Suite, Lite does not have MIDI out), select Live->Preferences on Mac (Options->Preferences on Windows).
Find the MIDI tab and make sure Pi Pico has a checkmark next to the output device.
Piotr Gaczkowski
