Hackaday.io Hackaday.io
Sign up Log in
Capacitive Soil Moisture Sensor
Basic analog capacitive moisture sensor made from three transistors, two diodes, and a handful of passives!
customelectronicsCustomElectronics
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
3 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 11
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
433
0
3
1
Team (1)
  • customelectronicsCustomElectronics
Join this project's team
hardware
ongoing project
Plants low power analog capacitive
This project was created on 06/11/2023 and last updated 2 years ago.
Description
The sensor is intended to be used in houseplants to remind people like me (who forget their own name sometimes) when their plants need to be watered. It can be "calibrated" for different levels of desired soil moisture by adjusting the depth that the sensor is inserted into the soil.
Details
Files
Three Transistor Capacitive Moisture Sensor_2023-03-11.zip
Gerber files for PCB
x-zip-compressed - 19.05 kB - 06/11/2023 at 01:36
Download
Components
  • 3 × 2N7002 (SOT23) Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × 1N4148 (SOD123) Discrete Semiconductors / Diodes and Rectifiers
  • 1 × 680pF Ceramic Capacitor (0603) Surface Mount Capacitor
  • 1 × 80pF-270pF Ceramic Capacitor (0603) Tuning Surface Mount Capacitor (should be higher value if you want to trigger earlier on)
  • 2 × 2 Megohm Resistor (0603) Surface mount resistors
View all 11 components
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Capacitive Soil Moisture Sensor", please tell us the reason.
Send message
Remove Member
