PIN Number access - I know it's a tautology
06/20/2023 at 10:17 • 0 commentsVersion 1.10+ has an optional 4 digit identification number for access. A 4 digit PIN can be added from the setup screen and then when the sidecar boots up it will ask for the PIN before you can access the two factor tokens. An incorrect pin will reboot the device and ask again. The delay can be set in includes if needed.
Matt
Matt Perkins
