Raspberry Pi Based Mobile ADSB Receiver
I built this simple ADSB receiver with GPS and feeds to popular flight location aggregation sites like ADSB.fi
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
With the right antenna and a good location, this receiver is very capable of pulling in signals 250-300 miles away.
I used a Pi4 but it can just as easily be built on a Pi3. If you don’t need a screen, even a Pi Zero will work surprisingly well with the right adaptors. I have also built a screenless version using the Le Potato SBC and a few other Linux-based boards with some slight modifications to the code. The computing horsepower to make all this possible is minimal.
More details and a parts list can be found at the below link
