Already finding weird behavior in other things...
A project log for 10kW (30kW pulse) Electronic Load
All we need to do get some big resistors and connect them up in different combinations, right?
tinfevertinfever 07/14/2023 at 03:180 Comments
I was testing the load stage at higher currents today after installing a second MOSFET on the PCB to support a 0.5R load resistor, when I ran in to some bizarre turn-on behavior.
That's...not supposed to happen. Yellow is the FET_EN signal, Blue is the voltage across the FETs, Purple is the gate drive output to each FET, Green is the current through the load stage. This is on a 1R load resistor with a 6V supply from my bench PSU
At first I feared this might some complex interaction between the two MOSFETs. Could they somehow be turning on at different times and causing some weird feedback? But why would the current track the change in voltage if it isn't going below the FET threshold voltage? Is the 100k pullup driving the BJT push-pull gate driver stage not enough? I've really gone too far this time.
I started probing around as well as varying the frequency and pulse width from the signal generator:
Now the blue trace is the voltage applied to the load stage
What madness is this? I'd expect the voltage across the load stage to drop a little as the current increases due to the resistance of the cables, fuse, current shunt, etc. You can even see this happening at the very start, but then they start to become correlated. The input voltage drops and the current drops simultaneous...what?
The only thing that would make sense would be the... power supply.
Green is the current through the load stage, Blue is the voltage measured at the bench power supply terminals
Yup. The bench PSU is messing with me. Both of them, in fact. I have a Korad KA3005P and KD3005D that both show the same behavior. I'm not sure if it's the rapid change in current, or the somewhat inductive load, or something else. I'm just glad this isn't my problem this time!
I switched to the server PSU I'm using for a lot of this testing since it can supply 100A at 12V and the issue went away.
Yellow is the FET_EN signal, Green is the current.
Looks at those beautiful 22A 100us current pulses! You can clearly see how the inductance of the 0.5R load resistor is limiting us here. Pay no attention to the ugliness of the FET_EN signal. I think that's caused by current actually flowing back through the scope's earth connection to the PSU, since ground isn't ground when you're swinging this much current around over cables. That'll have to be its own blog post.
In case anyone is keeping tracking, this means the 8R, 4R, 2R, 1R, and 0.5R load stage configurations are working successfully, which covers a current range of 1.5A to 25A respectively. Tomorrow I'm going to assemble a 0.1R load stage that has to work at 122A, that's where things get serious.
