I attached the wired State Panels to the console frame using some two sided tape. Notice here that I have added a logo and some labels for the state panels.
Then I connected the bottom and top row panels with the cable I made and plugged in the cable from the Pi 4.
Finally I glued the six State Panels together to create a more stable connection between the PCBs and printed panels.
When the glue dried I placed the joined panels into the console. Nice clean fit with no jiggle. Just what I was looking for.
All that's left now is to calibrate the 96 sensors against this final configuration.
