jack-spkt.FCStd3D printed thing that holds the large sprocket to the jackshaft in place of the original wheel.fcstd - 92.35 kB - 07/02/2023 at 19:57 |
fw-front.FCStdHub for attaching the flywheel and sprocket onto the motor. In the unlikely event you need to adapt a VW flywheel to a 5/8 shaft, I've got you covered.fcstd - 194.89 kB - 07/02/2023 at 19:54 |
fw-back.FCStdBack part of flywheel sprocket hubfcstd - 36.65 kB - 07/02/2023 at 19:54 |
pulley.FCStdpulley used from before the chain upgradefcstd - 137.17 kB - 07/02/2023 at 03:44 |
wattmeter.tar.gzfirmware for the arduino-based wattmetergzip - 1002.59 kB - 07/02/2023 at 03:42 |
