Input and power wired mostly!
A project log for Thumb Term
Battery powered Linux-terminal handheld with front and rear inputs, 4.3" DSI LCD, a Pi 3A+, and GPIO breakout. WIP.
dan-a8ksh4Dan (a8ksh4) 07/22/2023 at 01:060 Comments
Solid progress.  I re-made the back 5-way switches with diodes the other way around. My first draft will get used in some other project another time.   And all input devices are wired up and working now!
And the power stuff is all soldered up now:
I would be doing final assembly but I goofed up the last print..  So I'll hopefully put it all together and not have unexpected issues with fit this weekend!
Aaaand a note about soldering to 18650 cells - I don't recommend it, but if you do, use flux and a hot iron.  Get a blob of solder on each end of the cell, clean up the flux with alcohol, and let it cool.   Tin your wires.  Then go back and solder the wires into the blobs, working fast so you don't put much heat into the cell.  It's better to spot weld or maybe use a battery holder.
And on this theme of doing responsible things, I will go back and add an axial fuse to my battery lead.  It's a good idea for safety.
