The goal of this project is to have a portable linux terminal for hacking that can be easily used outdoors on a nice day (but is still usable inside as well) that is powered primarily with solar power (but that also has the option to plug it in if necessary).
The challenges of this project are going to be space constraints, power, and cooling. I'm using an old, second-hand monochrome 240x64 dot-matrix lcd a Sharp 2.7" MiP LCD and a Waveshare 4.2" ePaper for the display and a raspberry pi zero w for the "brains" so power and cooling shouldn't be a huge issue there. However, the solar panel and the charging of the battery I expect will add some heat to the equation.
Space constraints will be tricky but hopefully doable. I have, altogether between the space in the bottom and the lid of the case, about 282x90x2.5 cm to work with (give or take a couple mm).
Aside from a couple of custom mechanical keyboards, this is my first major electronics project. I taught myself to solder for this project (with tips from my retired telephone engineer father-in-law) and am learning everything else I need as I go.
