New Screen Setup
A project log for The Solar Box
A cyberdeck housed in a bamboo clamshell case and powered with solar engery
nick-scratchNick Scratch 07/08/2023 at 15:160 Comments
I've decided on a dual-screen setup of a Sharp 2.7" Memory-in-Pixel display for the active work and a Waveshare 4.2" epaper display for output/reference. Both of these have active development and libraries/drivers for the hardware I'm using.
I feel bad for buying more new tech instead of recycling like I would have with the hantronix display (which actually is a powertip display?) but I can still use that for other projects down the line. It will be fun to hack on, but it ultimately doesn't fit the goal of this project as being an actively usable field tool.
The added bonus is that both of these displays together will draw even less power than the powertronix-whatever-it-is display.
