SOFT ACTUATOR ORTHOSIS
Empowering Lives
Overcoming Disability
Public Chat
The project's objective is the development of a prototype orthosis designed to provide effective assistance to individuals who have experienced a spinal cord injury (SCI) at the C6-C7 level, particularly in their ability to grasp objects. To overcome the limitations associated with conventional flexor hinge hand splints, this orthosis will incorporate a comfortable and adaptable design, incorporating a soft robotic mechanism in the middle and index fingers. This innovative approach not only enhances grip strength but also allows for a sustained grip during wrist movement. The modular design will allow for customization to suit various patient populations sharing similar physical characteristics. This groundbreaking innovation has the potential to significantly enhance the quality of life for affected individuals, granting them increased independence in their daily activities while also potentially benefiting those with hand impairments.
BACKGROUND
A spinal cord injury (SCI) is a critical medical condition that frequently leads to significant morbidity and enduring disability.
C6 and C7 tetraplegics have paralysis of finger and thumb flexor muscles but retain voluntary control of wrist extensor and sometimes wrist flexor and finger extensor muscles.
These individuals typically rely on wheelchairs, and in most cases, both hands are affected, resulting in a loss of sensory abilities in their fingers.
OBJECTIVES
Within the realm of prosthetics and wearables, there are two main categories: remedial and compensatory. Tenodesis splints for spinal cord injuries fall under the compensatory category. While the use of these splints can positively impact the user's life, they do not lead to improvements in finger dexterity.
Standard tenodesis splints allow movement for three fingers: the index, middle, and ring fingers. Although there is potential for accommodating more fingers, any additional fingers should only be included if there is a justified need. It is important to consider that attaching each finger to the splint can be a laborious process for the user, and one of the primary goals is to provide enhanced autonomy. Autonomy begins with the user's ability to independently put on the splint.
Challenges
User‐centric approach becomes indispensable in this project.
  • Weight Most of the current splints are aluminum.
  • Ratcheting and grip The splint should be easy to put on and off. It is important to consider that users do not have mobility on their fingers while they are putting them on. Sometimes they use their teeth to adjust straps.
  • Grip With mechanical devices, the grip works as long as the user is flexing their wrists. This can be tiring and strain the wrists.
  • Adaptability Every user is different. If some sections of the unit could be standardized, costs would go down.
  • Looks The appearance is important.
Common tasks that users with disability want to do
  • Changing their IC bags (Urinary drainage bag / Infection control drainage bag)
  • Turning pages on books, magazines, or loose sheets of paper.
  • Putting make up on.
  • Using a pen, signing papers. The ability to wear it and remove it.
  • Using food utensils: forks, spoons, etc.
  • Using a smartphone, stylus. (wheelchair).
  • Dressing up (infrequent). Not to get entangled.
EXISTING SOLUTIONS
The solutions that are already present in the market are the Flexor Hinge Splint and the Elastic Splint. Both of these devices exploit principles of mechanics to achieve the task of grasping objects.
The Flexor Hinge Splint replaces the tenodesis effect with a contraption. They are powered by wrist extensions and incorporate a ratchet mechanism for pitch adjustment. These splints are typically custom-made to fit the individual's anatomy, making them costly.
The Elastic Splint, instead, enhances the tenodesis effect with a contraption. The activation is provided by the wrist movement and the structure is partially tailor-made. An advantage is given by the possibility to regulate the elastic force changing the thread tension.
Both of these solutions have the main issue of relying on keeping the wrist extended while maintaining the grip thus limiting wrist movement.
THE PROMISE OF SOFT ROBOTS
Soft robots are pliable devices constructed from compliant materials, engineered to exhibit greater adaptability compared to conventional rigid robots. Their organic nature makes them a burgeoning technology in the field of rehabilitation, owing to their inclination toward more natural movements.
CONCEPT AND RESEARCH
The original idea for the device was to create a prototype that seamlessly combined soft robots to complement the grasping motion, employing one inner tube to enable finger bending and a second to provide wrist support.
OUR SOLUTION
We propose a solution that...
step - 495.22 kB - 11/04/2023 at 05:20
Download
step - 68.22 kB - 11/03/2023 at 07:21
Download
Adobe Portable Document Format - 29.44 kB - 11/03/2023 at 07:16
Preview
Download
step - 503.10 kB - 11/03/2023 at 07:12
Download
step - 1.14 MB - 11/03/2023 at 07:12
Download
View all 12 files
  • 1 × Arduino Nano BLE 33
  • 2 × MPU6050 IMU
  • 1 × Adafruit TB6612 Dual Channel Motor Driver
  • 1 × Micro Linear Actuator Input Voltage: 12V; Maximum Force: 64N; No Load Speed: 15mm/s
  • 1 × TTP223 Touch Button
View all 12 components
  • Pneumatic Actuation
    Benedetta Lia Mandelli11/04/2023 at 06:36 0 comments
    A linear actuator, equipped with a plunger at its end, pushes into a custom-cut 20ml syringe, transferring the contents into the silicone body.
    This offers the potential to utilize liquid instead of air, enhancing the efficiency of the device.
  • Kit
    Benedetta Lia Mandelli11/04/2023 at 06:27 0 comments
    Sold as a pre-assembled kit that must then be formed by a professional to ensure a snug fit.
    The splint will be available in different sizes based on the user's anthropometric measurements.
    The structure housing the silicone body will be parametrically designed according to the length of the patient's index finger.
    Both the PVC pipe and silicone body can be trimmed to the required size.
  • Splint
    Benedetta Lia Mandelli11/04/2023 at 06:26 0 comments
    The splint is crafted from low-temperature thermoformable material. It can be soaked in water at 60-70 c° (140-158 f°) for one minute, making it pliable for easy manipulation. Once the layout is cut, the entire assembly is combined with the ABS components to ensure proper positioning during forming.
    Layout cutting
    Assembly
    Heating
    Forming
  • Radial lock - Pinch regulation
    Benedetta Lia Mandelli11/04/2023 at 06:23 0 comments
    The user can adjust the width of the pinch by himself according to the object to be grasped.
  • Electronics - Battery State Control
    Benedetta Lia Mandelli11/04/2023 at 06:20 0 comments
    To power on the linear actuator a 12V battery is needed. The PCB integrates a properly dimensioned voltage divider used to read the voltage drop across the battery. Battery state is shown through an RGB LED.
  • Silicon finger supportive structure
    Benedetta Lia Mandelli11/04/2023 at 06:17 0 comments
    A supportive structure envelops the silicone, enhancing the control of bending and providing support points.
  • Silicone finger making
    Benedetta Lia Mandelli11/04/2023 at 06:15 0 comments
    Research aimed at optimizing energy transfer and relies on two main factors: the cross section of the body and the choice of material. The evaluation also considered the ease of reproduction.
    The silicone selected has shore 13.
    Once removed from the mold, the body is sealed with a piece of silicone-soaked cotton, which serves as a non-elastic layer.
    Cast
    Ectract
    Seal
    Cut
  • Soldering process
    Benedetta Lia Mandelli11/04/2023 at 06:05 0 comments
    For the realisation of the prototype, certain choices had to be made regarding the components to be used. The linear actuator selected is a 12V, we are currently investigating solutions to get to a 5V powered system in order to reduce the battery compartment size.
View all 8 project logs
  • 1
    ARDUINO CODE
    // Libraries
    #include <SparkFun_TB6612.h>
    #include <Wire.h>
    #include <Adafruit_Sensor.h>
    #include <Arduino_Helpers.h>
    #include <AH/Math/Quaternion.hpp>
    #include <Adafruit_MPU6050.h>
    #include "Adafruit_AHRS_Mahony.h"
    #include <ArduinoBLE.h>
    //MOTOR
    // Pins for all inputs, keep in mind the PWM defines must be on PWM pins
    #define STBY D7
    #define AIN1 D8
    #define AIN2 D9
    #define PWMA D10
    // the following constant is used to allow you to make your motor configuration
    // line up with function names like forward.  Value can be 1 or -1
    const int offsetA = 1;
    // Initializing the linear actuator
    Motor motor1 = Motor(AIN1, AIN2, PWMA, offsetA, STBY);
    //STATE MACHINE
    unsigned long sTime;
    unsigned long cTime;
    #define SM_START 0
    #define SM_IMU 1
    #define SM_FILL 2
    #define SM_DRAIN 3
    #define SM_MAINTAIN 4
    uint8_t cstate;
    uint8_t ostate;
    // IMU
    const int MPU1_addr = 0x68;  // I2C address of the first MPU6050 --> A4 + A5
    const int MPU2_addr = 0x69;  // I2C address of the second MPU6050 --> A4 + A5
    Adafruit_MPU6050 mpu1;
    Adafruit_MPU6050 mpu2;
    Quaternion q1, q2;
    Adafruit_Mahony filter1;
    Adafruit_Mahony filter2;
    //Wirst position
    bool wristExtended = false;  // Flag indicating whether the wrist is flexed or extended
    const int ThresholdH = 35;  // Threshold for wrist flexion/extension detection
    const int ThresholdL = -35;  // Threshold for wrist flexion/extension detection
    //Moving Average Filter
    const int numReadings = 10;             // Number of readings for moving average
    float DifferenceReadings[numReadings];  // Array to store angle differences
    int currentIndex = 0;                   // Index to keep track of the current reading position
    float filteredDifferenceRoll;
    float filteredDifferenceYaw;
    float filteredDifferencePitch;
    //FILL and DRAIN variables
    int flag;
    //BUTTON
    #define BUTTON_PIN 3
    int status;
    int button_state_old = 0;
    int flag_button = 0;
    // Voltage divider definitions.
    // Here I've reported my precise values for R1 (2.66K) and R2 (1K)
    // remember: you cannot apply more than 3.3V on analog input.
    // Having a voltage divider with those values (2.66K and 1K)
    // consent to apply on the voltage divider input a maximum of:
    // 3.3/VDK = 3.3/0.275 = 12V
    #define R1  2660
    #define R2  1000
    #define VDK  0.2732240437//(R2/(R1+R2))
    // since I'm using a Li-Ion battery 11.1V and you cannot apply
    // less than 5V on Vin pin, I define my "battery full" value as 11.1V
    // and "battery low" value as 5V
    #define BAT_FUL 11.1
    #define BAT_LOW 5
    #define BAT_DIS 20 //percentage
    #define BAT_CHARG 12 //voltage while connected to the line
    // analog pin connected to the voltage divider for battery
    // voltage reading
    #define AN_BAT  A3
    //LED defines
    #define RED_PIN  D6
    #define GREEN_PIN  D5
    #define BLUE_PIN  D4
    static long preMillis = 0;
    uint16_t b_averages=100; // average for battery
    // battery averaged value/actual value
    static float anBa=0;
    float anBa1;
    static uint16_t i_b=0; // battery readings counter
    static int flag_start = 1;
    void init_sm() {
      cstate = SM_START;
    void update_sm() {
      switch (cstate) {
        case SM_START:
          Serial.println("\nSM_CALIBRATION");
          ostate = cstate;
          cstate = SM_IMU;
          break;
        case SM_IMU:
          status = digitalRead(BUTTON_PIN);
          if (button_state_old == 0 && status){
              button_state_old = 1;
              flag_button = 1;
          if(button_state_old == 1 && !status){
              flag_button = 1;}
          if (((filteredDifferenceRoll < ThresholdL) || flag_button) && flag) {
            // Svuoto per un periodo
            flag_button = 0;
            Serial.println("\nSM_DRAIN");
            sTime = millis();
            ostate = cstate;
            cstate = SM_DRAIN;
          if (((filteredDifferenceRoll > ThresholdH) || flag_button) && !flag) {
            flag_button = 0;
            Serial.println("\nSM_FILL");
            sTime = millis();
            ostate = cstate;
            cstate = SM_FILL;
          break;
        case SM_FILL:
          flag=1;
          //Use of the drive function which takes as arguements the speed
          //and optional duration.  A negative speed will cause it to go
          //backwards.  Speed can be from -255 to 255.  Also use of the
          //brake function which takes no arguements.
          motor1.drive(-255,3000);
          motor1.brake();
          Serial.println("\nSM_IMU");
          sTime = millis();
          ostate = cstate;
          cstate = SM_IMU;
          break;
        case SM_DRAIN:
          flag=0;
          motor1.drive(+255,3000);
          motor1.brake();
          sTime = millis();
          ostate = cstate;
          cstate = SM_IMU;
          break;
    void setup() {
      //Initialize SM
      init_sm();
      //Touch Button
      pinMode(BUTTON_PIN, INPUT);
      //Battery LED
      pinMode(RED_PIN, OUTPUT);
      pinMode(GREEN_PIN, OUTPUT);
      pinMode(BLUE_PIN, OUTPUT);
      // IMU
      Wire.begin();              // Initialize the I2C bus
      initializeMPU(MPU1_addr);  // Initialize the first MPU6050
      initializeMPU(MPU2_addr);  // Initialize the second MPU6050
      // Initialize the angle difference readings array
      for (int i = 0; i < numReadings; i++) {
        DifferenceReadings[i] = 0.0;
      motor1.drive(255,3000);
      motor1.brake();
      //Serial
      Serial.begin(9600);  // opens serial port, sets data rate to 9600 bps
      setImu();
      updateValues();
    void loop() {
      long curMillis = millis();
      if (preMillis>curMillis) preMillis=0; // millis() rollover?
      if (curMillis - preMillis >= 5) // check values every 5mS
        preMillis = curMillis;
        //IMU----------------------------------------------------------------------
        /* Get a new sensor event */
        sensors_event_t a, g, temp;
        mpu1.getEvent(&a, &g, &temp);
        filter1.updateIMU(g.gyro.x, g.gyro.y, g.gyro.z, a.acceleration.x, a.acceleration.y, a.acceleration.z);
        mpu2.getEvent(&a, &g, &temp);
        filter2.updateIMU(g.gyro.x, g.gyro.y, g.gyro.z, a.acceleration.x, a.acceleration.y, a.acceleration.z);
        // Read IMU
        float w, x, y, z;
        filter1.getQuaternion(&w, &x, &y, &z);
        q1 = Quaternion(w, x, y, z);
        filter2.getQuaternion(&w, &x, &y, &z);
        q2 = Quaternion(w, x, y, z);
        Quaternion qprod = Quaternion().hamiltonianProduct(q1, q2.conjugated());
        EulerAngles angles = EulerAngles().quat2eul(qprod);
        const float piGreco = 3.14159;
        float yaw = (angles.yaw / (piGreco)) * 180;
        float roll = (angles.roll / (piGreco)) * 180;
        float pitch = (angles.pitch / (piGreco)) * 180;
        //String s = String(yaw) + "," + String(pitch) + "," + String(roll);
        //Serial.println(s);
        // Apply moving average filter to the acceleration difference
        //filteredDifferenceYaw = calculateMovingAverage(yaw);
        filteredDifferenceRoll = calculateMovingAverage(roll);
        //filteredDifferencePitch = calculateMovingAverage(pitch);
        //String s = String(filteredDifferenceRoll) + "," + String(roll);
        //String s = String(filteredDifferenceYaw) + "," + String(filteredDifferenceRoll) + "," + String(filteredDifferencePitch);
        updateValues(); // call function for updating Battery value
        update_sm();
    void setImu() {
      Serial.println("Adafruit MPU6050 init MPU1!");
      // Try to initialize!
      if (!mpu1.begin(0x68)) {
        Serial.println("Failed to find MPU6050 chip");
        while (1) {
          delay(10);
      Serial.println("MPU6050 Found!");
      mpu1.setAccelerometerRange(MPU6050_RANGE_8_G);
      Serial.print("Accelerometer range set to: ");
      switch (mpu1.getAccelerometerRange()) {
        case MPU6050_RANGE_2_G:
          Serial.println("+-2G");
          break;
        case MPU6050_RANGE_4_G:
          Serial.println("+-4G");
          break;
        case MPU6050_RANGE_8_G:
          Serial.println("+-8G");
          break;
        case MPU6050_RANGE_16_G:
          Serial.println("+-16G");
          break;
      mpu1.setGyroRange(MPU6050_RANGE_500_DEG);
      Serial.print("Gyro range set to: ");
      switch (mpu1.getGyroRange()) {
        case MPU6050_RANGE_250_DEG:
          Serial.println("+- 250 deg/s");
          break;
        case MPU6050_RANGE_500_DEG:
          Serial.println("+- 500 deg/s");
          break;
        case MPU6050_RANGE_1000_DEG:
          Serial.println("+- 1000 deg/s");
          break;
        case MPU6050_RANGE_2000_DEG:
          Serial.println("+- 2000 deg/s");
          break;
      mpu1.setFilterBandwidth(MPU6050_BAND_21_HZ);
      Serial.print("Filter bandwidth set to: ");
      switch (mpu1.getFilterBandwidth()) {
        case MPU6050_BAND_260_HZ:
          Serial.println("260 Hz");
          break;
        case MPU6050_BAND_184_HZ:
          Serial.println("184 Hz");
          break;
        case MPU6050_BAND_94_HZ:
          Serial.println("94 Hz");
          break;
        case MPU6050_BAND_44_HZ:
          Serial.println("44 Hz");
          break;
        case MPU6050_BAND_21_HZ:
          Serial.println("21 Hz");
          break;
        case MPU6050_BAND_10_HZ:
          Serial.println("10 Hz");
          break;
        case MPU6050_BAND_5_HZ:
          Serial.println("5 Hz");
          break;
      Serial.println("Adafruit MPU6050 init MPU2!");
      if (!mpu2.begin(0x69)) {
        while (1) {
          delay(10);
      mpu2.setAccelerometerRange(MPU6050_RANGE_8_G);
      switch (mpu2.getAccelerometerRange()) {
          break;
          break;
          break;
          break;
      mpu2.setGyroRange(MPU6050_RANGE_500_DEG);
      switch (mpu2.getGyroRange()) {
          break;
          break;
          break;
          break;
      mpu2.setFilterBandwidth(MPU6050_BAND_21_HZ);
      switch (mpu2.getFilterBandwidth()) {
          break;
          break;
          break;
          break;
          break;
          break;
          break;
      Serial.println("MPU OK!");
      delay(100);
      filter1.begin(5);
      filter2.begin(5);
    void initializeMPU(int addr) {
      // Function to initialize the MPU6050 for accelerometer readings
      Wire.beginTransmission(addr);  // Start communication with the MPU6050
      Wire.write(0x6B);              // PWR_MGMT_1 register
      Wire.write(0);                 // Set to zero (wakes up the MPU-6050)
      Wire.endTransmission(true);
      Wire.write(0x1C);  // ACCEL_CONFIG register
      Wire.write(0x00);  // Set full-scale range to ±2g
    void readAccelerometer(int addr, int16_t& ax, int16_t& ay, int16_t& az) {
      // Function to read accelerometer data from MPU6050
      Wire.write(0x3B);  // Start with register 0x3B (ACCEL_XOUT_H)
      Wire.endTransmission(false);
      Wire.requestFrom(addr, 6, true);  // Request 6 bytes from MPU6050
      ax = Wire.read() << 8 | Wire.read();  // Read the accelerometer data
      ay = Wire.read() << 8 | Wire.read();
      az = Wire.read() << 8 | Wire.read();
    void readGyroscope(int addr, int16_t& gx, int16_t& gy, int16_t& gz) {
      // Function to read gyroscope data from MPU6050
      Wire.write(0x43);  // Start with register 0x43 (GYRO_XOUT_H)
      gx = Wire.read() << 8 | Wire.read();  // Read the gyroscope data
      gy = Wire.read() << 8 | Wire.read();
      gz = Wire.read() << 8 | Wire.read();
    float calculateMovingAverage(float newValue) {
      // Function to calculate moving average of angle differences
      // Update the array with the new value
      DifferenceReadings[currentIndex] = newValue;
      // Increment the current index and wrap around if needed
      currentIndex++;
      if (currentIndex >= numReadings) {
        currentIndex = 0;
      // Calculate the average
      float average = 0.0;
        average += DifferenceReadings[i];
      average /= numReadings;
      return average;
    void updateValues() {
      // read battery value
      anBa1=analogRead(AN_BAT);
      anBa+=anBa1;
      i_b++;
      if (i_b==b_averages||flag_start)
        flag_start = 0;
        Serial.println(anBa);
        anBa/=b_averages; // averaged analog value
        float voltage=anBa*(3.3/1023); // voltage on pin (if 3.3V => ADC gives 1023)
        voltage=voltage/VDK; // real voltage on the voltage divider input = battery voltage
        float Vin = voltage;
        Serial.print("Battery: ");
        Serial.print(voltage,2);
        Serial.print("V (");
        // calculate percentual battery
        // we must consider BAT_FUL=100% and BAT_LO=0%
        // report voltage to range having 0 as lower limit and (BAT_FUL-BAT_LO) as higher limit
        // for having percent value
        voltage-=BAT_LOW;
        voltage/=(BAT_FUL-BAT_LOW);
        anBa=voltage*100;
        // keep percent value in the range 0-100
        if (anBa<0) anBa=0;
        else if (anBa>100) anBa=100;
        Serial.print(anBa,1);
        Serial.println("%)");
        if(anBa < BAT_DIS){
          digitalWrite(RED_PIN, HIGH);   // Turn on the red LED
          digitalWrite(GREEN_PIN, LOW);  // Turn off the green LED
          digitalWrite(BLUE_PIN, LOW);  // Turn off the blue LED
        } else if (anBa >= BAT_DIS && Vin<BAT_CHAR) {
          digitalWrite(RED_PIN, LOW);    // Turn off the red LED
          digitalWrite(GREEN_PIN, HIGH); // Turn on the green LED
        } else if(Vin>=BAT_CHARG){
          digitalWrite(GREEN_PIN, LOW); // Turn on the green LED
          digitalWrite(BLUE_PIN, HIGH);  // Turn off the blue LED
        i_b=0;
        anBa=0;
    //MOTOR FUNCTIONS ------------------------------------------------------------------------------------------------------------------
    // Drive in direction given by sign, at speed given by magnitude of the
    //parameter.
    void drive(int speed);
    // drive(), but with a delay(duration)
    void drive(int speed, int duration);
    //currently not implemented
    //void stop();           // Stop motors, but allow them to coast to a halt.
    //void coast();          // Stop motors, but allow them to coast to a halt.
    //Stops motor by setting both input pins high
    void brake();
    //set the chip to standby mode.  The drive function takes it out of standby
    //(forward, back, left, and right all call drive)
    void standby();
    //Takes 2 motors and goes forward, if it does not go forward adjust offset
    //values until it does.  These will also take a negative number and go backwards
    //There is also an optional speed input, if speed is not used, the function will
    //use the DEFAULTSPEED constant.
    void forward(Motor motor1, Motor motor2, int speed);
    void forward(Motor motor1, Motor motor2);
    //Similar to forward, will take 2 motors and go backwards.  This will take either
    //a positive or negative number and will go backwards either way.  Once again the
    //speed input is optional and will use DEFAULTSPEED if it is not defined.
    void back(Motor motor1, Motor motor2, int speed);
    void back(Motor motor1, Motor motor2);
    //Left and right take 2 motors, and it is important the order they are sent.
    //The left motor should be on the left side of the bot.  These functions
    //also take a speed value
    void left(Motor left, Motor right, int speed);
    void right(Motor left, Motor right, int speed);
    //This function takes 2 motors and and brakes them
    void brake(Motor motor1, Motor motor2);
View all instructions
