North American Cyberarms Cyberdeck
Cyberdeck from an old pistol case for the 2023 contest
My entry to the 2023 cyberdeck contest under the "ROM Construct" category. based on a pistol case for the case, a raspberry pi 3 and a keyboard that is the unholy union of half qwerty and butter stick. Goals: A handy, sturdy, throw in a pack and go for a walk tool for writing, coding and some simple gaming. Maximum budget (because the cybperpunk dystopia we live in is more interested in shareholder value than employee quality of life) is 50 bucks. Thankfully I've got a decent sized junk bin.
halfbutterqmk.tar.bz2
qmk source files for the keyboard
x-bzip - 0 bytes - 08/16/2023 at 03:24
Download
CaseBottom - BottomPlate.stl
Bottom half, slots for keyboard, mouse and wires
Standard Tesselated Geometry - 7.82 MB - 08/16/2023 at 03:22
Download
CaseTop - Top beizel.stl
Top half, cutout for screen, blinkenlights and protoboard
Standard Tesselated Geometry - 3.21 MB - 08/16/2023 at 03:22
Download
Keyboard - Ergo Plate.stl
Ergonomic version of the keyboard plate
Standard Tesselated Geometry - 819.22 kB - 08/16/2023 at 03:22
Download
Keyboard - Ergo Case.stl
Case for the ergonomic keyboard
Standard Tesselated Geometry - 1.34 MB - 08/16/2023 at 03:22
Download
View all 10 files
  • 1 × raspberry pi or equivalent
  • 10 × cherry mx compatible keys, lighter is better
  • 1 × 5 way rocker switch
  • 1 × 3d printed keyboard plate
  • 15 × small diodes
View all 19 components
  • Got a deck!
    Patrick Tait08/13/2023 at 20:16 0 comments
    As finished as any cyberdeck project can be, just need to do some documentation and the project video
    As a bonus, blinkenlights, and my sons opinion on the case
  • Fitting the power in
    Patrick Tait08/08/2023 at 03:44 0 comments
    the PiJuice, short of a basic power brick, is the quickest and easiest way way to add power to a Pi Project.  It's plug and play, snap it on the top and you have power.  Add some software and you have fancy battery monitoring and control.  It has nifty features like programmable LEDs and buttons.  It has two notable downsides: 2.5 amp limit, which shouldn't be a problem for my project, and hat format means it adds a decent amount of vertical clearance to the Pi. it's a thicc board.
    A large pair of pliers and a quick twist later:
    and then we just snip those bits off -
    and I flew too close to the sun and cracked my flush cutters
    If that is god telling me I should have gotten a power board that fit instead of forcing in what I had, god should have made staying under budget easier on this project.  New flush cutter coming tomorrow, but I'll be able to fit all three boards,  LCD driver (blue) power (red) and pi (green)
    since I want to use the power feature, I have to make sure the I²C pins connect, so when I do trim the top parts off, going to want to keep the 5v, gnd and 3 and 5 pins intact to plug in.
  • power plug
    Patrick Tait08/07/2023 at 23:27 0 comments
    Added a power plug and a reset switch.  Debated making the plug flush but with it sticking out a bit it looks like a one eyed duck and that amuses me
  • starting to look like a deck
    Patrick Tait08/04/2023 at 20:43 0 comments
    Sadly I have to use a different mouse, the relacon is too thick to fit, but I found a pocket mouse I can substitute.
  • Work on the top plate
    Patrick Tait08/01/2023 at 22:06 0 comments
    Now that i have the screen in hand and can get an idea of exactly where everything goes, it's time to work on the top plate.
    Had a few prototyping blocks around, so will be using those to access 5V, 35 and ground on the fat block and various to be determined and hopefully swappable lines on the skinny one, hole on the bottom right is for the USB hub, and the big hole in the top left is for the headphone jack, little holes below the monitors are for LED's
    Rev 1 didn't have the depth to fit the raspberry pi, rev 2 is on the printer right now:
  • Parts arrived
    Patrick Tait07/31/2023 at 21:55 0 comments
    Screen and new pi showed up, pretty soon we'll start having a minimum viable deck
  • measure twice, print once
    Patrick Tait07/31/2023 at 02:44 0 comments
    test print on the bottom half of the deck, which is designed to hold the keyboard, mouse and a videogame controller.  The keyboard case was the wrong size and the whole thing was about a cenimeter too short.  Remeasure, reprint and move on.
    width was due to me accidentally not replacing the default with the proper variable, keyboard outline was due to using the wrong revision of the keyboard,  Onshape is handy but not being able to integrate it into my normal version control is a headache
  • rpi not booting, battery extraction
    Patrick Tait07/29/2023 at 23:10 0 comments
    waiting on a USB ttl cable so I can check and see if there is anything on the boot log, if I have to get a new pi that would more than double the budge of the build, bah.
    Pulled some batteries out of my laptop that died previously in the project:
  • International Keyboards
    Patrick Tait07/20/2023 at 21:55 0 comments
    Here's a first draft layout for a french azerty keyboard, there are more extra characters than I would assume and I'm making some guess at how useful they are but it's not the worse start
  • Fixed computer, making progress, waiting on diodes and the screen
    Patrick Tait07/20/2023 at 02:13 0 comments
    Same keyboard, different hand sizes.
View all 18 project logs
