PC Monitor Jr v2
Monitor Windows computer CPU and memory usage, plus temperature on an ESP32 with a TFT Display
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is an modernized version of https://hackaday.io/project/174927-cpu-monitor-jr This open source project provides for a real time display of the Windows CPU and memory usage plus temperature on an ESP32 with a TFT monitor. The project uses of two platforms. The first is Windows, with a Windows service gathering and sharing the computer's performance data. The second is an ESP32, displaying that data on a TFT display. To the left is an example of two (ESP32) LilyGo T-Display S3 devices each monitoring a separate computer at the same time. Displayed are the names and LAN IP addresses of each computer, as well as, their CPU temperature, memory percentage used, historical total and current core loads. The top device is monitoring a four core Windows computer, the bottom device is monitoring a 24 (48 virtual) core Windows computer. For more information please see either: https://rlatour.com/cpumonitorjr/ or https://github.com/roblatour/CPUMonitorJr/
