Design the case
A project log for TechNIK's Cyberdeck
A 3D printed compact and customizable linux terminal
nik-reitmannNik Reitmann 07/26/2023 at 18:540 Comments
Started with the blue side profile
Trackball mount
Powerbutton (right) and power led (left)
Keyboard mount
Outer display frame
Inner display frame with raspberry mount. The display (pink) sits between the outer (yellow) and the inner frame (blue)
Rotary knoob
Without cover
Both display frames
All parts without case and keyboard
rear panel
IO panel
