Print
A project log for TechNIK's Cyberdeck
A 3D printed compact and customizable linux terminal
nik-reitmannNik Reitmann 07/26/2023 at 19:280 Comments
# Print
The printing time for all parts was approx. 20 hours. I printed the case in two parts, so fewer supports were needed and the holes for the mouse buttons and trackpad etc. were printed without any problems. In addition, I couldn't print it out in one go with the Bambu X1C, the case has the dimensions 253x253x104mm and the Bambu actually has a build volume of 255x255x255mm. However, the bamboo has a small area in the XY movement which it cannot use because the filament cutter is located there. Interesting fact, but didn't help me that much.
both display frames
display frame
one case side
one case side
