Glue case together
A project log for TechNIK's Cyberdeck
A 3D printed compact and customizable linux terminal
nik-reitmannNik Reitmann 07/26/2023 at 19:310 Comments
Glued with Araldite epoxy resin (also fills the gap)
With inner and outer display frame
With keyboard mount (which is also the 2nd part of the bottom cover (white)
Testing my new CAD skills: the bottom cover (white) seems to fit with the inner display frame (black resting on the little white feet of the bottom cover).
