Simple Arduino Touch Activated LED Project
By using an Arduino and a touch sensor, it is possible to control the switch of the LED light through touch sensing.
This project is an Arduino based touch activated LED light project. This simple and fun project allows electronics enthusiasts to learn how to use an Arduino and sensors to build an interactive LED control system. When the user's touch sensor is touched, the LED light will be on, and when the user touches the sensor again, the LED light will be off. This interactive control method adds fun and convenience to the use of LED lights. The project can be extended for home automation, small interactive installations, etc.
Project use code
// Define the pin for the LED
int ledPin = 13;
// Define the pin for the touch sensor
int touchSensorPin = 2;
// Define a variable to store the LED state
int ledState = LOW;
// Define a variable to store the previous touch sensor state
int lastTouchState = LOW;
void setup() {
  // Set the LED pin as an output
  pinMode(ledPin, OUTPUT);
  // Set the touch sensor pin as an input
  pinMode(touchSensorPin, INPUT);
  // Initialize serial communication
  Serial.begin(9600);
void loop() {
  // Read the state of the touch sensor
  int touchState = digitalRead(touchSensorPin);
  // Check if the touch sensor state has changed
  if (touchState != lastTouchState) {
    // If the touch sensor is touched
    if (touchState == HIGH) {
      // Toggle the LED state
      ledState = !ledState;
      // Update the LED state
      digitalWrite(ledPin, ledState);
      // Output the LED state to the serial monitor
      if (ledState == HIGH) {
        Serial.println("LED ON");
      } else {
        Serial.println("LED OFF");
    // Update the previous touch sensor state
    lastTouchState = touchState;
 Code fragment explanation
This Arduino code creates a simple project that uses a touch sensor to control an LED. The LED will turn on when the touch sensor is touched and turn off when touched again. The code starts by defining the pin numbers for the LED (pin 13) and the touch sensor (pin 2). It also declares variables to store the LED state (HIGH for on, LOW for off) and the previous state of the touch sensor.
In the setup() function, the LED pin is set as an output, and the touch sensor pin is set as an input. The Serial.begin() function initializes serial communication, allowing us to monitor the LED state through the serial monitor.
In the loop() function, the code reads the current state of the touch sensor using digitalRead(). If the touch sensor state has changed since the last reading, the code checks if the touch sensor is currently touched (HIGH state). If it is touched, the LED state is toggled using ! (NOT) operator. The LED state is then updated accordingly using digitalWrite() to turn the LED on or off.
Finally, the LED state is output to the serial monitor using Serial.println(), providing a message indicating whether the LED is ON or OFF. The previous touch sensor state is also updated to match the current state, ensuring that the LED is only toggled once for each touch event. The loop() function continues to run repeatedly, continuously checking for changes in the touch sensor state and controlling the LED accordingly.
  • 1 × Arduino development board (such as Arduino Uno)
  • 1 × Touch sensor module
  • 1 × Led light
  • 1 × 220 ohm resistor
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
View all 6 components
  • 1
    Step 1: Gather the Components
    You will need the following components to build the Arduino touch-activated LED project:
    • Arduino board (e.g., Arduino Uno)
    • Touch sensor module
    • LED (any color of your choice)
    • 220-ohm resistor
    • Breadboard
    • Jumper wires
  • 2
    Step 2: Connect the Components
    Follow these steps to connect the components on the breadboard:
    1. Connect the positive (longer) leg of the LED to digital pin 13 on the Arduino through the 220-ohm resistor.
    2. Connect the negative (shorter) leg of the LED to the ground (GND) pin on the Arduino.
    3. Connect the output pin of the touch sensor module to digital pin 2 on the Arduino.
  • 3
    Step 3: Upload the Code
    Open the Arduino IDE and copy the provided code into a new sketch. Make sure your Arduino board is connected to your computer via USB. Select the correct board and COM port from the "Tools" menu, and then click the "Upload" button to upload the code to the Arduino.
View all 5 instructions
