Here is a test print on a 3D-printed PETG panel:
I started by coating the panel with some UV paint.
This is the mask that will be used:
I exposed the mask for 25 minutes:
Cleaning-up the unexposed paint:
The letters and lines came out pretty thick, that may mean that 25 minutes might have been slightly too long and shorter exposure time would be fine.
