Hello, It's time for an update on my 80286 project!
I began to work on my 1st motherboard PCB prototype in the past month since working on a breadboard is becoming too challenging.
![](https://cdn.hackaday.io/images/1197341697389823898.png)
The goal of this version is to consolidate everything that is working on my breadboard version to a cleaner setup but let me add new things on top. I had also added a ISA port to plug a ISA debug card with the Arduino Mega for debuging.
Here's the final result after receiving the produced boards :
![](https://cdn.hackaday.io/images/5339191697390372124.jpg)
The first test run :
![](https://cdn.hackaday.io/images/3702231697390468395.jpg)
When testing the board I accidentally burned my 82C284 Clock Driver chip, luckily I was able to make a replacement with a GAL chip on a little protoboard.
And here's the first run I did with the debug card installed to troubleshoot the PPI :
![](https://cdn.hackaday.io/images/2055601697390397669.jpg)
Finally after a week of troubleshooting, a lot of cut traces and bodge wires, I was able to make my VFD screen work again thru the PPI :
![](https://cdn.hackaday.io/images/2547961697391493384.jpg)
The next step will be to use this platform to learn more about x86 assembly and begin work on a BIOS.
Until next time...
Dom
