A quick update after a 3 weeks break!
The processor board is fully built and I was able to free run the CPU without being connected to the motherboard. I already found some improvement to be done on the next revision :
- Move the GAL chip use to generate to act as a 82284 Clock diver and the 82288 Bus Driver to the motherboard chipset.
- Add some pins header along the edge connector to give me easy access to all the signals for debugging.
![](https://dominicemond.files.wordpress.com/2023/12/pxl_20231204_121334886.jpg?w=1024)
The next step was to populate the motherboard and began the work on the CPLD in Quartus.
![](https://dominicemond.files.wordpress.com/2023/12/chipset-2.jpg?w=1024)
![](https://dominicemond.files.wordpress.com/2023/12/io_cs_logic-2713608055-e1702745981946.jpg?w=974)
![](https://dominicemond.files.wordpress.com/2023/12/capture-decran-2023-12-16-115829.png?w=1024)
![](https://dominicemond.files.wordpress.com/2023/12/pxl_20231201_171250945-1.jpg?w=1024)
It was the time for the big test... and it didn't go well..
The first issue was a huge short on the power rail, I found out that my VCC and GND pins on my edge connector where flipped. To be sure I looked back the schematics and confirmed that the A and B sides of the connector where not flipped :
![](https://dominicemond.files.wordpress.com/2023/12/capture-decran-2023-12-16-123237.png?w=455)
![](https://dominicemond.files.wordpress.com/2023/12/capture-decran-2023-12-16-123208.png?w=475)
Then I realized that the footprint that I used was wrong... the A and B sides where indeed flipped and where mislabelled!
So now that I know the issue, I need to take a decision if I spin a new revision for my processor card or if I do a workaround for now in case I found more issue before ordering a new board.
I worked on the revision v0.4 of the processor board, I fixed the edge connector, added the pins headers and remove the GAL. I still need to integrate the 82288 bus controller in my chipset later.
![](https://dominicemond.files.wordpress.com/2023/12/capture-decran-2023-12-16-134024.png?w=1024)
Before ordering this new revision, I want to do more test on my current v0.3 revision if possible. I have ordered a PCI extension that I will re-wire to be able to use my v0.3 board and make sure that I do not have other issue with the design.
![](https://dominicemond.files.wordpress.com/2023/12/41ukzxihhl._ac_.jpg?w=490)
Next steps
- Make a workaround with a PCI extension to be able to test the current v0.3 board.
- Integrate the 82288 bus controller in my chipset.
- Make a new processor card revision.
