• STL Files of the Final LeOn Version
    Andrei Gramakov12/08/2023 at 22:08 0 comments
  • Test. Fully Assembled with a Toy Attached
    Andrei Gramakov11/12/2023 at 21:42 0 comments
  • High-Level Software
    Andrei Gramakov11/04/2023 at 23:13 0 comments
    Separation of the Software (independent of the hardware logic) and the Firmware (dependent on the hardware) has allowed me to implement the main robot logic on Windows without involving MCUs at all.
    I packed all the code in a set of CMake projects producing static libraries. Including main.cpp - it is also a component. Then I assemble everything into an executable file - currently for the Windows platform. It can be called a Windows robot simulator:
    The next step is to implement the driver part and then connect them together.
    Quick QnA:
    • Can it be done directly on MCU? Yes.
    • Would it be faster to do this? Yes!
    • Would it be scalable when the project grows? No!
    • Could I easily port parts of the code to my other projects? No.
    Source Code: https://github.com/an-dr/LeOn/tree/7c41b8b35d2450aba1adc6544145845a02f9a0eb/software/main_controller
  • Interfaces Update
    Andrei Gramakov10/26/2023 at 21:06 0 comments
    Initially I wanted to implement interfaces as simple header files, but after reading articles from Jacob Beningo (e.g. https://www.beningo.com/how-to-write-epic-hardware-abstraction-layers-hal-in-c/) I’ve decided to go with abstract classes and structures with function pointers. This allows me to pack the interface as separate components, decoupling other components even more. The result is on the updated component diagram:
    More details are in the repository: https://github.com/an-dr/LeOn/blob/e0b4142b7202b88d46830cca5cbb5a7b23a262a4/docs/architecture-arc42.md#building-block-view---software
    P.S. It’s incredibly sad, that GitHub still does not support Plant UML rendering. C'mon, GitHub!
    P.P.S. Yes, I’m not coding still. Maybe, if you do the right architecture, you don’t code 🤔?
  • Hardware Prototype v.1
    Andrei Gramakov10/25/2023 at 19:36 0 comments
    Here are the main mechanical modules that I developed to test my implementation when it is ready. They may look simple, but practically work 🙂
    Cat Interaction Mechanism
    I took a favorite toy of my cat - a piece of filament for 3D printers.
    Transportation System
    The Transportation System is based on two the cheapest possible step motors
  • Software Architecture
    Andrei Gramakov10/25/2023 at 19:19 0 comments
    Before coding, let’s decide on the Software Architecture. Based on my previous decision, I’m going to have two main parts:
    • Main Application
    • Movement Server
    • Movement Interface - to communicate between them (e.g. CAN library)
    Each part will have a high-level and a low-level logic. I will use two terms, movement - for transportation in space, and motion - for any other physical activities. In total, we will have:
    • Motion Controller
    • Motion Driver
    • Movement Controller
    • Movement Driver
    To break the direct dependency, Controller→Driver let’s use a Hardware Abstraction Layer Interface, so we will have a dependency on a stable interface rather than on a driver that can be changed in the future:
    ControllerHALDriver
    By doing so, we isolate the high-level logic of hardware changes.
    Let's introduce two more terms:
    • Software - logic, depending on a use case, a practical application.
    • Firmware - logic, depending on the used hardware
    The resulting architecture looks this way:
    The next steps will be:
    1. Find/Develop appropriate interfaces
    2. Implement HAL mocks
    3. Implement the Software
    4. Find appropriate drivers
    5. Implement HAL
  • Hardware Details
    Andrei Gramakov10/18/2023 at 19:32 0 comments
    Meanwhile, I’m preparing a simple prototype, since my architecture already has enough information for hardware steps.
    I'm going to go cheap 28BYJ-48 stepper motors and probably a DC motor for the cat toy. When it is done, I would like to port it to a different hardware and verify that my architecture does not require any changes, something like this:
  • Sequence
    Andrei Gramakov10/16/2023 at 20:38 0 comments
    And the last thing that we will need before start building a real thing. The logic.
    The overall robot algorithm is the following:
    The interaction between the robot components is described in the following sequence diagram:
    Next time, finally, assembly of the first prototype and coding! We will add the other architectural details as we work.
  • The Building Blocks
    Andrei Gramakov10/16/2023 at 20:30 0 comments
    The system contains four main building blocks. I'll describe them next. I tried to be general in the terms, so I could decide on the details later, keeping the architecture relevant whatever I will decide to change later.
    1 - The Main Controller
    It consists of a Controller module and a CAN Module. The Controller uses GPIO to interact with the Cat Interaction Mechanism and the CAN module.
    2 - Physical Transportation System
    Also has a brain, interaction via CANbus with the main controller. Uses some physical transportation mechanism (wheels, legs, etc.) via an Interface module (e.g. a motor controller)
    3 - Cat Interaction Mechanism
    It is a mechanical device connected to the main controller. The interface module takes a logical commands (e.g. via GPIO configuration) and translates it to the mechanical movement
    4 - Power System
    A simple system of a power source and two lines:
    • High-current - supplies the mechanical devices
    • Low-current - supplies the logical devices
  • High Level Structure
    Andrei Gramakov09/28/2023 at 21:46 0 comments
    After some thinking process, I’ve split the robot into 4 subsystems
    • Main Controller
    • Physical Transportation Subsystem
    • Power Subsystem
    • Cat Interaction Mechanism
    To illustrate the structure, I used the Block Definition Diagram of SysML (I hope, correctly):
    As you can see, the CAN interface is already part of the architecture. It is so, because I want to reuse it in my other robot that already uses CAN but.
    Meanwhile, I’m not sure 100% about the interface detail for the Cat Interaction Mechanism… Probably I’ll remove it, since I don’t have a reason to decide about it right now, and according to the Clean Architecture principles, decisions about details should be delayed as much as possible.
    Next time I'm going to develop white boxes for the subsystems.
