Create your own affordable GPS/GNSS Base Station and Receiver with NTRIP server capabilities using the ESP32 and Unicorecomm UM980. This DIY guide walks you through hardware assembly, component connections, antenna selection, and firmware flashing. Elevate your GNSS applications with the UM980's superior performance. For the latest and most detailed instructions, refer to the original guide.
