The card itself contains a CPU UA880D which is a clone of the Z80 CPU operating at up to 4MHz. Furthermore, an oscillator with a frequency divider with the possibility of adjustment with a jumper. And a reset circuit.
Unfortunately, I didn't avoid using wire jumpers, which also have to be this long due to an error in the design (I didn't make holes for them). In addition, I chose the wrong spacing of the CPU socket, so I also made a reduction.
I already have the basic skeleton of my computer ready, so it's starting to take shape. On the top floor is the backplane with the cards and on the bottom is the ATX power supply and HDD.
A simple tool for testing the function of the CPU, which uses HW to impose a NOP instruction on the processor, which only increases the address and thus performs a basic test of the function.
So it turned out that the power supply, which was supposed to be functional, does not work. Fortunately, I have a promised old PC from which I will have a larger but functional source.
