At this point we have something that at least proves out the concept of using TDR to measure soil moisture, but requires an oscilloscope to actually measure. To make this project work, I'll need to make a self contained way to measure that timing difference and it also can't cost much. So I want to avoid any ADC based based designs and instead focus on comparator and timing based designs.
The first design I attempted to replicate was from an EDN article. There are some low res partial schematics in the article that I recreated:
And also the PIC24F based digital section:
Which resulted in the following layout:
If you look closely, you may notice some unpopulated parts. I didn't take a picture until after I had already harvested a few components for the next version. There was a next version because this design ended up not having the resolution I needed to detect the differences between moist soil and slightly less moist soil. In the end it could measure a delay change of about 500ps which wasn't enough to reliably detect the moisture difference over a day.
So even if it didn't work out, I learned a few things while working with the PIC microcontroller and the CTMU. As mentioned in the article, the PIC has a current source it can start and stop charging a capacitor with. It then can measure the voltage on that cap to determine how much time has passed. Even with the current source set to the highest setting and using just the internal capacitance, the charge was too small to get an accurate reading. Also, the documentation on how to set the flags to get the right charge range where incorrect and had to be determined experientially.
The code is pretty simple and mostly configuration, so I'm including it here for completeness.
#define RANGE_5_50uA 1 // 5.50uA
void CtmuTimeConfig(unsigned int range, signed int trim)
// Step 1 Configure the CTMU
CTMUCON1 = 0x0000; // Disable CTMU
CTMUCON1bits.TGEN = 0; // Disable Time Generation mode
CTMUCON1bits.EDGEN = 1; // Edges are enabled
CTMUCON1bits.EDGSEQEN = 1; // Edge sequence enable
CTMUICONbits.ITRIM = trim; // Set trim
CTMUCON1bits.CTTRIG = 1; // Trigger output enabled
CTMUICONbits.IRNG = (range & 3); // Set range
// This line does not apply to all devices
//CTMUCON2bits.IRNGH = (range>>2); // set high bit of range
CTMUCON2bits.EDG1MOD = 1; // Edge mode
CTMUCON2bits.EDG1POL = 1; // 1 - rising edge 0 - falling edge
CTMUCON2bits.EDG1SEL = 2; // 8 = CTED13 Pin 6 || 2 = CTED2 pin 15
CTMUCON2bits.EDG2POL = 0; // 1 - rising edge 0 - falling edge
CTMUCON2bits.EDG2MOD = 1; // Edge mode
CTMUCON2bits.EDG2SEL = 8; // 8 = CTED13 Pin 6
// CTMUCON2bits.IRSTEN = 1; // enable reset by external trigger
// CTMUCON2bits.DSCHS = 4; // ADC end of conversion
// Step 2 Configure the port Ports
TRISBbits.TRISB12 = 1; // Configure RB12 as a input CTED2
ANSBbits.ANSB12 = 0; // disable analog on RB12
TRISBbits.TRISB2 = 1; // Configure RB2 as a input CTED13
ANSBbits.ANSB2 = 0; // disable analog on RB2
TRISAbits.TRISA0 = 1; // Configure RA0 as a input
ANSAbits.ANSA0 = 1; // Configure AN0/RA0 as analog
AD1CHSbits.CH0SA = 0 ; // Select AN0
// Configure the cap drain output pin
TRISAbits.TRISA3 = 0; // RA3 as output
PORTAbits.RA3 = 0; // Set output low
// Step 3 configure the ADC
AD1CON1 = 0x0000; // Turn off ADC
AD1CON1bits.SSRC = 0; // 4 - CTMU is the conversion trigger source 0 - manual
AD1CON2 = 0x0000; // VR+ = AVDD, V- = AVSS, Don't scan,
AD1CON3 = 0x0000; // ADC uses system clock
// AD1CON3bits.ADCS = 8; // conversion clock = 1xTcy
AD1CON5 = 0x0000; // Auto-Scan disabled
AD1CON1bits.ADON = 1; // Enable ADC
AD1CON1bits.ASAM = 1; // Auto-sample
// Clear CTMU Interrupt
IFS4bits.CTMUIF = 0;
// Step 4 - 6 Enable the current source and stop manual discharge
CTMUCON2 &= ~0x0300; // clear the edge status bits
CTMUCON1bits.CTMUEN = 1; // Enable the CTMU
CTMUCON1bits.IDISSEN = 1; // begin manual discharge of cap
PORTAbits.RA3 = 1; // Drain the external cap
__delay_ms(10); // Wait for the drain to complete
CTMUCON1bits.IDISSEN = 0; // stop discharge of cap
PORTAbits.RA3 = 0;
static void config_ADC_ext_cap() {
ANSA = 0; // Clear register select
ANSB = 0;
// Configure RB4/AN15 to read the voltage on external cap
TRISBbits.TRISB4 = 1; // Configure RB4 as an input
ANSBbits.ANSB15 = 1; // Configure AN15 as analog
AD1CHSbits.CH0SA = 0b01111; // Pick AN15
#define MAX_TRIGGER_CHECKS 100
Main application
int main(void)
char print_buf[128] = {0};
// initialize the device
SYSTEM_Initialize();
SSD1306_Begin(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS);
SSD1306_set_rotation(SSD1306_ROTATE_180);
// SSD1306_Display();
// __delay_ms(2000);
SSD1306_ClearDisplay();
SSD1306_DrawText(2, 7, "Hello, world!", 1);
SSD1306_Display();
// Configure the pulse output pin
TRISBbits.TRISB13 = 0; // RB13 as output
ANSBbits.ANSB13 = 0; // disable analog on RB13
PORTBbits.RB13 = 0; // Set output low
unsigned int result;
CtmuTimeConfig(0, 0); // 550uA
int count;
int flip = 0;
while(1)
count = 0;
PORTBbits.RB13 = 1; // Trigger pulse
PORTBbits.RB13 = 0; // Reset pulse
// Wait for CTMU interrupt
while(IFS4bits.CTMUIF == 0) {
count++;
// Bail if we fail to trigger
if(count > MAX_TRIGGER_CHECKS) {
goto main_loop_end;
//config_ADC_ext_cap();
// Make sure the interrupt is already cleared
IFS0bits.AD1IF = 0;
// Trigger ADC conversion
AD1CON1bits.SAMP = 0;
// Step 7: Wait for ADC interrupt
while(IFS0bits.AD1IF == 0){}
// Steps 8-11
IFS0bits.AD1IF = 0; // clear the interrupt
result = ADC1BUF0; // read ADC result
PORTAbits.RA3 = 0;
// Write results to screen
char format[] = "ADC: %d %s";
int slen = sprintf(NULL, format, result, flip ? "." : " ");
if(slen < sizeof(print_buf)-1) {
sprintf(print_buf, format, result, flip ? "." : " ");
} else {
sprintf(print_buf, "Print too long");
SSD1306_DrawText(2, 7, print_buf, 1);
SSD1306_Display();
main_loop_end:
// Wait a bit
__delay_ms(10);
flip = !flip;
return 0;
I didn't write much in the way of documentation or screen shots of the experimental results since I was focused on getting it working, and since it didn't, I don't really feel like going back and setting it up again.
At this point it was back to the drawing board for the sensor side of the project, which we'll take a look at in the next log.
Wonderful to go thru your work. Recently I am building a tdr soil sensor for agri for a smart system. I see the AliExpress versions (MEC, JCXT) have their pcbs with an STM32L452RE, an lmv324, an rs485 and voltage regulators to measure soil conductivity, moisture and temperature. There is no signal generator like 74AC14 and the STM32L452RE they use works at 40MHz so there is no chance of getting pulses into or out of probes of 2-10ns. Your option to go for low cost is mine too. I aim to use Esp32 C3 with Lora (heltec chip) instead of stm/rs485 so the sensor sends data to wifi/bt/lora directly. Your choice of using a timing based ic and low cost adc inspires me too. It will be fascinating to get 4-10ns reflection for delta t for time to give moisture. That leaves one question: if we want to measure Electrical Conductivity and moisture than we will need both the rising peak height (VT/VR) and delta t. Avoiding a 1Gsps adc will not give the rising peak height? Or is there a way around? Hope to get an answer. Anyways liked your log a lot.
