Marriage of housing and mainboard
A project log for Full Passive AMD Ryzen 7 7700x DIY build
DIY build using heatpipes and two massive 300mm x 235mm x 75mm ribbed cooler blocks to form a zero noise passive cooled PC
bastelbausBastelBaus 10/16/2023 at 21:200 Comments
I printed the layout of the mainboard holes, punshed, drilled and and tapped holes to mount teh mainboard as well as the alu frame.
With some distance bolts I mounted the PCB to the alu cooler (in fact only to one of both, not to induce mechanical stress to the board when the coolers would relative move.
To mount the power supply, I used some spare aluminium sheets, drilled holes and fixated the sheets inside the alu profiles
