Bending and mounting the heat pipes
A project log for Full Passive AMD Ryzen 7 7700x DIY build
DIY build using heatpipes and two massive 300mm x 235mm x 75mm ribbed cooler blocks to form a zero noise passive cooled PC
bastelbausBastelBaus 10/16/2023 at 21:390 Comments
First I 3D printed a heatr pipe bender. This worked well but maybe I was not carefull enough in the beginning when bending, you will read later whey ...
Step by step I adjusted all five heatpipes not to touch anything and form a good connection from the CPU towards the cooler:
To fix the copper blocks I also used a small piece of alu with holes and drilled screw holes inside the alo cooler.
