Putting it together with thermal paste
A project log for Full Passive AMD Ryzen 7 7700x DIY build
DIY build using heatpipes and two massive 300mm x 235mm x 75mm ribbed cooler blocks to form a zero noise passive cooled PC
bastelbausBastelBaus 10/16/2023 at 21:460 Comments
In contrast to a normal cooler with only one surface between CPu and cooler, I had to mount several pieces at teh same time. It was a bit of a challenge! I tried to first mount the ends at the cooler, then put the pipes in the copper block at the CPU and then closing this copper block.
As can be seen in the lower right picture, the thermal pasted was quite well spread over the copper block (I had to dismount, but read more later .....). Also the alu sheets (I think it was 2mm or more) bended quite a bit when i tried to apply pressure to the blocks.
