Final mounting and benchmark
A project log for Full Passive AMD Ryzen 7 7700x DIY build
DIY build using heatpipes and two massive 300mm x 235mm x 75mm ribbed cooler blocks to form a zero noise passive cooled PC
bastelbausBastelBaus 10/16/2023 at 22:000 Comments
Finally I 3D printed a mount for a slim DVD drive, mounted a USB/SD Card front pannel on the alu profiles and a 3D printed fixture and mounted the front plane on some wood spacers and applied an old Apple sticker :-)
The final benchmark results are really nice and the only noiseI I spotted was from my (old) monitor when I did not turn off the sound card :-) Initial test over 19.000 points in Cinebench R23 and also the stability test is only minor points below 19.000.
