tcrt5000 abl-sensor carrier v1.0.stlsensor carrier release v1.0, has holes for m2 nut and screw for mounting (only tested on Cytron version, holes are included for the pins of the more common version)Standard Tesselated Geometry - 112.58 kB - 10/29/2023 at 12:34 |
sensor carrier v0.2.stlsensor carrier prototype v0.2, has holes for m2 nut and screw for mounting (only tested on Cytron version, holes are included for the pins of the more common version)Standard Tesselated Geometry - 112.58 kB - 10/29/2023 at 10:26 |
application/x-zip-compressed - 7.14 MB - 10/29/2023 at 10:26 |
sensor carrier v0.1.stlsensor carrier prototype v0.1 (only tested on Cytron version, holes are included for the pins of the more common version)Standard Tesselated Geometry - 112.97 kB - 10/27/2023 at 18:09 |
