We are almost at the end of our project and and near the final date for the project, so it's time to combine all our work and design the final product. But before doing it we had a little issue with one of our sensor, after almost an hour of hard work and research we failed, so we decided to use another sensor wich after some test was working way better than the old one. After resolving our little issue and plug-in all the component on the arduino board we decided to lengthen some cables, and to do this we had to enamel some copper cables and solder some cables.
