CBJT Logic
Complementary bipolar junction transistor logic - like CMOS, but with NPNs and PNPs
This project is about an experimental logic circuit topology using complementary BJTs in place of N- and P-channel MOSFETs in traditional CMOS circuits. It may or may not work.
The idea comes from a simple mistake that apparently I was not the only one to make. About 20 years ago, I decided to design a discrete audio amplifier. Not having thought about it for a while before that, I got confused about the emitter-follower output, and made something like this:
At first, I couldn't figure out why the transistors got so hot. A co-worker who had previously designed audio amps for a boutique audio house pointed out that I had the transistors reversed; these were common emitter switches, not followers. In this configuration, once the supply voltage exceeds about 2*Vbe, the transistors bias each other on and draw lots of current. @esot.eric mentioned a similar learning experience regarding an H-bridge design from around the same time period :-)
At some point, I wondered what happens with supply voltages less than 2*Vbe - then, the circuit looks a lot like the classic CMOS inverter. I didn't do anything with it at the time, but the subject of unusual transistor circuits recently came up in another thread. It seems like there's enough interest to make this into an actual project...so here goes.
Portable Network Graphics (PNG) - 27.80 kB - 01/21/2017 at 05:29
Preview
CBJT_MPSHxx.asc
LTspice simulation for inverter chain using MPSH10/MPSH81 pairs
plain - 10.26 kB - 01/20/2017 at 18:18
Download
  • Leaded version with feedback
    Ted Yapo01/29/2017 at 01:41 3 comments
    I soldered together a test using through-hole 2N390{4,6} transistors and 1.6k input / 2.2k feedback resistors. This test included four inverters driving either input of a NAND gate (also made with 2.2k feedback resistors):
    I tested this the same way I had done the SMT version: using a level/impedance/edge rate converter to drive the input with brief (~20ns), isolated (~100 kHz) pulses of either polarity. Like before, one of the output edges is delayed relative to the others, and this delay drops with input pulse length. I decided to use single, short pulses (about 24 ns after the inverter chain) to measure the NAND gate delays. This corresponds to a single pulse of a 21 MHz signal, so these results should be valid for systems clocked at this speed or below - and you can ignore the variable delay; this is a worst-case.
    Upper Input Driven
    With the lower input tied high, and the upper input driven, I observed the following waveforms (yellow = input, cyan = output).
    The rise and fall times vary from 1.5 ns to 3ns. These are fast edges and would require some thinking about long wires or traces in a system using these gates. With the positive input pulse, the two propagation delays are equal at about 2.5 ns. With the negative input pulse, one propagation delay is 1.5 ns (the output rising edge), and the other is 5.4 ns (the output falling edge).
    Lower Input Driven
    Here, the rise and fall times are longer, ranging from 1.8 ns to 3.9 ns. With the negative-going pulse, we see delays of 2 .0 and 7.2 ns. With the positive-going pulse, the delays are 2.9 and 3.7 ns.
    The 7.2 ns is the worst case of any observed - this is really the number you should think about to evaluate these gates. If you were building a small module, maybe a flip-flop or counter, you might be able to take advantage of some of the faster delays instead of simply assuming 7.2 worst-case. Generally 7.2 seems to be the number, assuming the minimum pulse widths in the system are 24 ns or more - corresponding to a system clock of 21 MHz or less.
    I think the take-away from this exercise is that the feedback resistor solves the problem with isolated pulses. There are probably ways to improve things, including splitting the input resistor like was published in the 1950s. I might leave it at this, though.
    Well, maybe one PCB for a counter or something, since I have the SMT transistors, and the R's and C's are dirt cheap.
  • Feedback Version Tests
    Ted Yapo01/22/2017 at 17:39 3 comments
    I hadn't home-etched a board since I discovered OSH Park (first order 1/12/13). Actually, before that, I used another service that didn't do soldermask or silkscreen, only offered one size board, and made you use their proprietary layout software. I also walked to school - uphill both ways; kids these days have it easy. Anyway, my bottle of ferric chloride is at least five years old, but it still works:
    It's a 5-stage ring oscillator with MMBT3904/MMBT3906 devices and the 2R (feedback) design. I didn't have 1.6k 0805 resistors, so it uses 1.5k and 2.2k. The bottom of the board is solid copper, and ground connections are made with wire "vias" in drilled holes. At 1.2V supply, the thing runs at 30.3 MHz, indicating a propagation delay of 3.3 ns. This is significantly longer than the simulations, but not really that bad. I don't think the 1.6k -> 1.5k substitution is to blame; it didn't make much difference in the simulation - but it might be causing other issues described below.
    Thinking there might be something wrong, I built a version with through-hole parts, too:
    This one uses 1.6k resistors. It runs at 33.4 MHz, for a propagation delay of around 3.0 ns at 1.2V. If you turn up the voltage, you can get it to peak around 37MHz, at high current drain. At high enough voltages, the speed drops again. I can't explain the difference in speed between the two versions. The TO92's are bona fide Fairchild transistors from a reliable distributor; the MMBT's are no-names I (probably) bought on ebay. Maybe they're not the real thing? Of course, this could be layout issues, too - is that long feedback line to blame? I think it's only about 250ps long electrically. And those 1.5k R's? Hmm.
    Pulse Testing
    Since the output impedance of these gates is so low, and the edge rates so fast, the output of my 50-ohm signal generator isn't a good source for testing. I decided to build a buffer with a 74AC02 quad NOR (because I have a ton of them). The edge rates of the AC logic are around the same as I have seen with these CBJT gates, and I made a voltage/impedance converter network so that the output is around 1.2V peak with a 9-ohm impedance:
    This circuit assumes a 5V supply for the 74AC02 and a 12-ohm output impedance for these NOR gates - I had previously measured around this value. Using this circuit at the output of my signal generator produces waveforms that look like the output of the CBJT inverters. Here's the adapter soldered together with the SMT test circuit:
    First Impressions
    So, I fired up a 10 MHz square wave input, and measured the output at the end of the chain of 5 inverters (with the ring oscillator feedback trace disconnected). Here are the waveforms (yellow = input, cyan = output):
    The rise time is about 2.1 ns, and the fall time 1.5 ns: fast edges. The measured propagation delay is 2.7 ns on average. This is faster than the ring oscillator measurements. You can also see that my generator at 50% duty cycle doesn't appear to be exactly 50%. Maybe the 74AC02 converter is stretching one side?
    Changing Duty Cycle
    The non-feedback design had a problem with transistor saturation at high or low duty cycles. This version has its own peculiarities, namely it stretches isolated pulses. As before, a 50% duty cycle input is fine, but isolated pulses are distorted a little. In this case, the pulse (either high-going or low going) is stretched by an amount inversely proportional to the pulse width - very counter-intuitive. For example, here are input pulse widths of 18.5 and 133ns producing output pulses of 31.3 and 137 ns:
    This is a stretching of 12.8 ns for the shorter pulse and 4 ns for the longer one. Bizarre. This happens for negative-going isolated pulses, too. And, it goes away with near-50% duty cycles, like before. It may be that this would be improved if I had 1.6k resistors in there instead of 1.5. I can try later with through-hole components where I have a stock of the 1.6k.
    One way to look at this pulse stretching is as an additional...
  • 2N390x CBJT Logic
    Ted Yapo01/21/2017 at 03:10 17 comments
    I think I've tweaked the component values into something possibly usable. The feedback resistor seems to improve the speed tremendously - by keeping the transistors out of saturation - at the cost of greatly reduced gain. But maybe we don't need that much gain? Here are the latest component values:
    the feedback resistor is new. It keeps the voltage on either base away from the rails to prevent either transistor saturating. An unfortunate side effect of this arrangement is a greatly reduced gain - at DC, the gain is approximately the ratio of the two resistors 2.2k / 1.6k = 1.375. Yes, this is very small - I thought it would be too small to be useful, but maybe it's OK, if you're careful. To get a feel for just how small this is, here's the voltage transfer function, which would normally be a sharp step function for an inverter:
    For most of the input voltage range, this is a linear amplifier. It's only at the extremes that it starts to look like a logic gate. But, since the output stage is symmetrical and low-impedance, and the input stage high-impedance, maybe this is enough gain to build logic circuits. Theoretically, you only need a gain of 1 after any losses...
    Then again, consider the speedup capacitor. At 10 MHz, that 100 pF capacitor has an impedance of about 160 ohms, so the gain is now around 14. That doesn't sound so bad.
    I built an early hardware test (with different RC values) of a ring of inverters with feedback resistors. At 1.1V supply, they were happy to just sit there and bias themselves to 1/2 the supply without oscillating - the gain was too low. At 1.2V, they always started ringing, and once started, they kept going as the supply was turned down to about 0.7V. So, I started simulating things at 1.2V instead of 1.1. The final supply voltage will probably need a tuning knob.
    Speed Simulations
    The original problem from a few logs back was that the logic worked well with high-speed square waves, but not at low or high duty cycles. I'm convinced now that rapid switching was keeping the pair out of saturation. A short pulse after a sustained high or low input wasn't enough to pull one of the pair out of saturation. The added feedback resistor holds the base voltage close to the midpoint, keeping both transistors out of saturation. This allows the gate to respond to brief, isolated pulses as well as waveforms with high repetition rates. Here's a test waveform at the input and output of a chain of 10 inverters:
    The measured delay for 10 inverters is around 16 ns, or 1.6 ns per inverter. This is significantly faster than what I had seen before. I haven't constructed any of these inverters yet, so I can't be sure it will work with real components. The initial low period above is a test for the saturation problem. Without the feedback resistor the PNP saturates on the initial stretch, and we get this - no output at all:
    I suspect the output would eventually start switching because this is only a 5 MHz square wave, but I didn't let the simulation run that long.
    Fan-out Test
    In this simulation, the second-to-last stage drives a fan-out of 10 inverters.
    This slows down the trailing edge of the first pulse so that it happens at a 31 ns delay (instead of 16 ns with the simple inverter chain). With a fan-out of 5, the delay is 24 (as opposed to 16) - so maybe a rough rule of thumb is that fan-out is roughly equivalent to cascading stages. It looks like driving 2 inputs delays the signal about as much as chaining 2 inverters. If the delays were all due to RC effects, this would be the case. This is not great, but might be acceptable. Again, I haven't measured this on the hardware yet.
    In any case, increasing fan-out decreases switching speeds. You see this with CMOS logic where the input capacitance of added driven inputs slows down the transition speeds. Although with integrated CMOS families, the effect is not this pronounced.
    Input/Output Impedance
    I roughly estimated the output impedance of the stage at 9 ohms. The input impedance is...
  • MPSHxx Teaser: would you believe 500ps?
    Ted Yapo01/20/2017 at 18:18 17 comments
    I shouldn't post this yet; there's surely some catch that will prevent you from going this fast. But, I'm doing it anyway. One of my favorite NPN/PNP pairs are the MPSH10 / MPSH81 RF transistors. Obsolete in TO92 now (although I have a thousand or so kicking around), they're still available in SOT23 as MMBTH10 / MMBTH81. With an ft of 600+ MHz, this pair is twice as fast as my other "fast" favorites, the 2N3904/2N3906 (300 MHz ft). Anyway, I couldn't help but simulate some CBJT inverters with the RF pair. Here's the input to, and output from a chain of 10 inverters. One edge is delayed by 3.6ns, the other by 5.0 ns. That equates to a propagation delay of under 500ps per inverter. Pretty fast.
    Here's the circuit. It might be difficult to find in the parameters, but the input resistor is 5.1k, the speedup capacitor 47p, and the feedback resistor 15k. The power supply is 1.2V.
    If you want to play around in LTspice with this, I've uploaded the simulation file. I haven't even simulated a 2-input gate yet, so that may or may not work. I also haven't built one of these yet. Even testing it may provide some unique challenges.
    I am still working on choosing the R's and C's to optimize the 2N3904/2N3906 pair. I started with a 1k input resistor because I have a giant reel of them from a late-night ebay purchase years ago. This is perhaps not the best objective function for optimizing the design :-) So, I'm having a close look at the R's and C's, considering speed, power, fan-out, etc, and then testing on hardware to make sure the simulations didn't lie. It's going to take a little while longer.
    UPDATE
    I ran a 5-inverter ring oscillator simulation with these transistors. This makes it look like actual propagation delays are closer to 1 ns. I still have no idea if these speeds will be achievable in reality.
  • No, it's not that fast
    Ted Yapo01/18/2017 at 16:32 29 comments
    I stayed up pretty late looking at this stuff - it just didn't make sense. Finally, after playing with the simulations, I found something. The complementary NPN/PNP pair can switch very fast if it is switched continuously - like with a 50% duty cycle pulse. This somehow keeps both transistors biased, or keeps them out of saturation, or something, that allows them to switch very quickly. After a period of time this "magic quality" wears off, and they switch slowly again. I don't have a full explanation yet, but I've seen it in simulation and on the hardware now. I started with the simple inverter circuit again: here simulated with 1 nF and 100 pF caps:
    when you drive the 100 pF cap version with a 50% duty cycle square wave, you can get it to go 25 MHz (the limit of my current testing setup). With duty cycles other than 50%, the waveforms fall apart. Here are some scope shots for a 3 MHz input with various duty cycles. Yellow (lower trace) is the input to the inverter; cyan (upper trace) is the output.
    30%
    40%
    50%
    60%
    70%
    80%
    This is not just a case of minimum pulse widths - for example, here's the same circuit driven at 10 MHz with 50% duty cycle. The high time and the low time are both shorter than the 30% and 80% duty cycles above, but there's no problem at all with the output:
    The same thing happens with the 1 nF capacitor, just at different frequencies. This effect is also present in the ring oscillator, which naturally assumes around a 50% duty cycle, so it is able to oscillate very quickly.
    Something is happening in the transistor pair that I don't understand. I don't think the effect is really due to the duty cycle - I suspect that a recent pulse makes the pair faster for a period of time. If another transition happens within this window, the pair will remain fast. Once the effect has worn off, the pair will be slow for the next transition. I can't fully explain what is happening inside the transistors yet, but I see the same effect in LTspice, where it's much easier to make measurements, so I have a shot at figuring it out.
    The real bummer is that this invalidates all the previous speed testing. I haven't fully re-run the tests yet with isolated pulses instead of square waves, but a quick look at the scope puts the propagation delays in the 25-35ns range. It's not quite as bad as a CD4001, but it's no match for even the 7404.
  • Looking for the Goldilocks capacitor
    Ted Yapo01/18/2017 at 02:30 4 comments
    UPDATE: the speeds measured here don't represent the true switching speed of these gates. See this log for more details.
    I initially settled on 1 nF speedup capacitors because they seemed to perform better in simulations - which were done with lower-frequency signals. The value did seem large at the time, but it seemed to work OK in practice, even though the ring-counter simulation would go much faster with smaller capacitors. I finally got around to trying smaller capacitors on the real hardware. With 100pF caps substituted for the old 1 nF's, everything goes more than twice as fast (with a catch, discussed below). The ring counter went from around 10 to 25 MHz:
    This frequency implies an average propagation delay of 3.92 ns. The scope measures 4.0 and 4.9, but may be confused by the under/overshoot. In any case, it's more than twice as fast as the previous circuit which had around 9.5ns of average propagation delay. A 74AC04 inverter has a typical propagation delay of 3.5 (TPHL) or 4.0 (TPLH) ns. This silly CBJT logic has gone from 74HC speeds to 74AC. Or so it would seem.
    What's the catch?
    Knowing my luck, there has to be a problem somewhere. It didn't take long to find it, either. At lower speeds (when driven with the signal generator), the waveforms fall apart - I saw this behavior in the simulations, too, which made me think larger caps were necessary. For example, a chain of inverters driven with a 1 MHz squarewave looks terrible (below, left). The same inverters look fine with a 2 MHz input (below, center), and OK to the top of my generator at 25 MHz (10 MHz shown below right) - some of that ringing is the ground leads on the probes; I was too lazy to solder on Z0-probes.
    100 pF just isn't enough at lower frequencies, which is bizarre, because it should be all about edges. Did I screw up and have the DDS set for a sine wave output?? Is the DDS edge rate lower for lower frequencies? Now I'm going to have to re-check when I get a chance - maybe this is something simple. It would be convenient if this bizarre behavior at low frequencies just went away :-)
    And the NAND?
    The NAND gate performance was also improved with the smaller capacitors - at least for higher frequencies. Driving the lower input showed a 3.3 ns TPLH and a 6.3 ns TPHL (the 74AC00 has 6.0 and 4.5 ns at 5.0V, respectively):
    With the upper input driven the NAND shows a 3.0 ns TPLH and a 6.3 ns TPHL - the input speeds are now basically symmetrical unlike with the 1 nF speedup caps. This is good.
    Oh, and if you drop the input frequency to 1 MHz or below, everything falls apart again. At DC, things work fine, as expected. I didn't measure the range of frequencies for which it's screwed up. I think this needs more bench time.
    It's another mystery!
  • NAND Issues Resolved
    Ted Yapo01/15/2017 at 17:11 10 comments
    Yes, it was poor layout on the prototype. A long alligator lead used to pull one NAND input high had enough inductance to resonate with the input network and cause problems. I was able to simulate it in LTspice by adding an inductor where the long lead was. The yellow trace is the base of the upper NPN, and shows ringing like I saw on the hardware:
    The 200 nH value was a complete guess - the actual inductance would depend on how I draped the alligator lead on the workbench, but the qualitative behavior was the same as I observed.
    To fix the problem, I tied the upper input high with a very short wire. The circuit doesn't show the resonances anymore, but the propagation delay is still relatively long and somewhat sensitive to input pulse width. For instance, with a 1 MHz input signal, the propagation delay is around 16.5 ns, rising to 19.7 ns at 10 MHz:
    On a longer timescale, the 10 MHz output still looks usable - I think you could go even higher:
    Edge Rates
    The fact that this circuit had issues with long leads on a "DC" input made me wonder about the edge speeds - that's what determines how much you have to worry about layout. The conservative rule of thumb is that you have to treat wires electrically longer than 1/6 of the transition time as transmission lines and terminate them at one or both ends to suppress waveform-distorting reflections. So, I decided to measure the edge rates.
    In the book, "High Speed Digital Design: A Handbook of Black Magic", Johnson and Graham describe five methods for estimating the rise time of logic signals:
    1. Differentiating the step response to yield the impulse response then taking the standard deviation
    2. 10%-90% direct measurement
    3. 20%-80% direct measurement
    4. Center slope measurement
    5. Maximum slope measurement
    (1) is interesting but too involved for now. (2) and (3) are complicated by the ringing, overshoot and odd shape of the waveforms. That leaves (4) and (5), which measure the slope of the rising edge, either at the center of the edge, or at the position of maximum slope. I just used cursors to measure the slope somewhere around the middle:
    The measured slew rate is 440 mV / 960 ps = 0.458 V / ns. According to this site, this is about half the slew rate of 74HC logic at 5V supply, which is about 0.9V/ns. But, the supply here is 1.1V, only 22% as high as the 74HC. According to Johnson and Graham, this translates into a CBJT rise time of:
    The same calculation for 74HC logic at 5V supply yields 5.5ns rise time, which agrees with 5ns figures I've seen quoted elsewhere. So, CBJT logic has edge rates about twice as fast as 74HC. While at first this might sound good, it means complications for laying out projects with CBJT logic. Light travels 72cm in 2.4ns, so you might have to treat wires as short as 12cm as transmission lines (assuming velocity factor = 1). You could add some more parts to slow the rise time (a simple RC network on the output would do it), but it detracts from the simplicity of the design. Maybe you can just add an extra RC at the output when you have a long run to drive.
  • NAND hardware tests
    Ted Yapo01/15/2017 at 02:34 9 comments
    I built a test jig for the simple NAND gate design. In order to drive it with "native" logic levels and impedances, I buffered the output of my signal generator (set to 1.1 V output amplitude) through a string of four inverters. This should produce close to a real CBJT drive for testing the NAND.
    The gate design is as it was before: two 2N3904's in series on the low side, with two 2N3906's in parallel on the high side. I tested and simulated with a 1.1V supply.
    At DC, the NAND gate works as expected. To test the high-speed performance, I drove one of the inputs while holding the other high. This turns the NAND into an inverter, and allows testing of the AC properties of the gate. Since the low-side transistors are in series, the two inputs are not identical - this caused the funny threshold seen in previous DC simulations.
    The upper input behaves roughly as expected with the lower input held high. Here's the waveform at the upper input (yellow) and the output (cyan) when driven at 1 MHz:
    I measured the propagation delay as 9.5 ns for the H->L output transition and 4.7 ns for the L->H using cursors. The scope's auto-measurement came up with 7.48 ns and 4.5 ns for the same delays. Close enough - and not bad, really.
    Testing the lower NAND input was much more interesting. There was a much bigger difference between the two propagation delays. Again, testing with a 1 MHz input signal, I measured 5 ns for the propagation delay when the output was going L->H - about the same as the upper input. But, the propagation delay for the other transition (H->L) was 20.7 ns, much longer than the upper input! Here's the L->H at ns delay:
    vs the H-> at 20 ns:
    I found this odd, partly because I hadn't seen any evidence of this in LTspice simulations. There, the delays are roughly identical:
    Two things come to mind: it could be bad spice models or parasitics in the layout. But playing around a bit found something even more odd - the delay depends on the input pulse frequency. At 1 MHz input, the delay was 20ns - this grew to a maximum of around 40ns with a 5 MHz input, but then the delay abruptly dropped again at 6 MHz! It was also clear that there was some instability involved - you can see in the the 6 MHz cyan trace (lower right). Here are 1, 3, 5, and 6 MHz plots. The output also peaks above the supply voltage before the transition ( you can also see this in the simulation above).
    I probed around a bit, and found the problem (but not the solution) - there is some odd resonance on the node between the two 2N3904's. Here are the waveforms at that node (cyan) at the same frequencies:
    You can see that the ringing starts when the input signal goes low. For long pulse widths, the ringing has died down by the next transition. For shorter widths, the ringing can interfere with the next edge, extending the delay time by an amount that depends on what phase of the ringing the edge coincides with.
    I still don't know where that resonance is coming from. It doesn't happen in the simulation. I'll have to spend some more time with the board to figure it out. I think this can be fixed. Maybe it's just poor layout on the prototype.
    Even if this is an unavoidable feature of these logic circuits, this behavior will just limit the maximum usable clock frequency.
    Misc. Observations
    It was a bit of a mystery how the output stage switches so quickly - shorter than the transistors should be able to turn off. I looked at the simulation closely - the transistors are still slow to turn off, but the opposing one turns on quickly and dominates the output. This causes some huge shoot-through current spikes in the output stage. It may be enough to warrant a bypass capacitor per output pair. This is just something you'd need to work around if you wanted to use this logic to build something.
    The common LM317 "adjustable" regulator is a fixed 1.25V...
  • Speeding Up the NOT Gate
    Ted Yapo01/10/2017 at 02:04 22 comments
    I played with the inverter simulation a bit - before testing the speed on the NAND gate, I figured I'd get things straight with the NOT. Adding the base resistors drops the power consumption as expected, but also dropped the oscillation frequency from 2.4 MHz to about 500 kHz. OK, I'll add the speedup caps. Simulations pointed to 1nF as a good value - which seemed large to me, but works OK on the board:
    With the 1k base resistors and 1nF speedup caps added, I tested the ring oscillator at a bunch of different voltages. I hooked channel 2 (cyan trace) to the power lead to label the images with the supply voltage.
    550 mV
    Again, I saw oscillations down to about 0.4V supply voltage, but things only started to stabilize above 500 mV. Here it is running at about 5kHz.
    707 mV
    This logic is probably only truly usable above 700mV (at the temperature I tested at - whatever that was). The circuit runs at 796 kHz, implying a gate propagation delay of 12.5 us, with a rise-time of 70.5ns (fall time not captured).
    808 mV
    By 808 mV, the speed has really picked up: f = 3.7 MHz, tpd = 27 ns, trise = 11.5 ns, tfall = 15.5ns. I forgot to measure the current.
    Note that those peaks on the top and bottom are above V+ and below ground - I forgot to move channel 2's reference to match channel 1.
    903 mV
    The speed has doubled now. f = 7.2 MHz, tpd = 14 ns, trise = 9.5 ns, tfall = 9.5ns, current = 4 mA / gate
    1.007 V
    A more modest speed increase. f = 9.5 MHz, tpd = 10.5 ns, trise = 10.5 ns, tfall = 10.5 ns, current = 8 mA / gate.
    I'm not sure I trust the scope's auto-measurement of rise and fall time with these waveforms. Next time I'm in the lab, I'll turn on the cursors and see exactly what it's measuring - although 1/5 of a division is 10 ns, which looks about right.
    1.102 V
    A little more speed. f = 10.51 MHz, tpd = 9.5 ns, trise and tfall about 10ns (scope auto-measurement screwed up), current = 12 mA / gate. This is probably the best voltage to run at.
    1.210 V
    Not much speed increase, just consuming more power. f = 10.58 MHz, tpd = 9.5 ns, trise = 10.5ns, tfall = 10.5ns, current = 18 mA / gate.
    1.306 V
    Speed reduced slightly, still more power consumption. 24 mA / gate now.
    1.404 V
    Less speed, more power - 30 mA / gate. The waveforms look superficially nicer, but at the cost of more than 3x the power used at 1.1V and a little less speed.
    Summary
    It looks like these inverters, with 1k base resistors and 1nF speedup caps, work best at around 1.1V supply. At this voltage, they show a propagation delay of about 9.5 ns. A look at the 74HC04 datasheet shows a typical 9ns tpd at 4.5V supply, which drops to 7ns at 5V supply. Amazingly, it would appear that this simple inverter is almost equivalent to 74HC logic in terms of speed. It doesn't seem like it should be...
    When I get a chance, I'll wire a 5/6 of a 74HC04 into a similar ring, and see what that looks like.
  • CBJT NAND Gate
    Ted Yapo01/09/2017 at 01:17 11 comments
    Here's a first try at a NAND gate. I took @Yann Guidon / YGDES's advice and went series on the bottom and parallel on top. If it works, the project is a success in some sense - every other gate can be constructed from NANDs. I've only simulated it so far.
    It's a straightforward adaptation of a simple CMOS NAND. I simulated the supply at both 0.8 and 1V, and it seems to work at either one, although a little better at 1V. The base resistors limit the input currents - these should have been on the inverter inputs, too. Because of the "stacked" input stage, the inputs are not symmetrical. For instance, here's the output voltage vs the top input with the bottom input held at logical 1 (1.0V):
    With the bottom input high, the NAND gate works like an inverter for the top input. And it looks like a pretty good one. The results aren't quite as good with the inputs reversed:
    Here, with the top input held high, the threshold for the bottom input isn't great. Still, if you specify the Vih parameter (minimum high input voltage) as maybe 0.65V, then it should be fine.
    I think this should be workable as a logic gate. I don't know about performance yet.
    AND Gate
    If you add another inverter stage to "clean up" the output, you get an AND gate with very nice thresholds on both inputs. Here's the circuit:
    and the output with the top input high and the bottom swept (the "bad' curve above):
    The output inverter produces nice thresholds for both inputs; their transfer functions are now basically identical.
View all 11 project logs
Marc wrote 12/07/2019 at 19:25 point
Symmetrical Transistor Logic R.H.Baker 1958 and other documents/books about transistor's logic :
http://marc.retronik.fr/old-logic/?dir=Transistors
Ted Yapo wrote 12/07/2019 at 23:16 point
wow, thanks for the link!
The universe is working well today; I was playing with some SPICE simulations of this stuff just this morning for a new project...
Marc wrote 12/08/2019 at 11:42 point
If you have more documentation about transistor's logic  and old logic, I'll be happy to add them to my site marc.retronik.fr
Thanks.
Yann Guidon / YGDES wrote 01/11/2017 at 10:26 point
Ted Yapo wrote 01/11/2017 at 12:54 point
Interesting - people have been here before (which isn't too surprising).
This allows a wider range of supply voltage, and reduces power consumption, although a quick SPICE test shows about 700ns of delay with no capacitors, which decreases to about 50ns with capacitors.  But that's just SPICE, and with no attempt to optimize anything.
Yann Guidon / YGDES wrote 01/11/2017 at 21:33 point
I hope your tests will show interesting performance ;-)
Ted Yapo wrote 01/10/2017 at 03:26 point
I found a link to the original article:
https://dl.acm.org/citation.cfm?id=1457779&CFID=714740953&CFTOKEN=69684497
those with access to the ACM library can read it (I no longer belong to the ACM or the IEEE - ask me about it sometime).  Anyway, I signed up for a free trial of a service called deepdyve that lets you read (but not download) this article - and many others from that era.  I can't justify paying for it, but I can read them for the next two weeks :-)
I'll post any interesting finds...
Yann Guidon / YGDES wrote 01/10/2017 at 03:31 point
screenshots ?
zakqwy wrote 01/09/2017 at 14:46 point
i will follow any project with such excellent soldering techniques.
Ted Yapo wrote 01/09/2017 at 23:54 point
Thanks!
I actually got an OLFA 9mm knife that you recommended for Christmas, but haven't had a chance to try it on copper clad yet :-)
zakqwy wrote 01/10/2017 at 00:31 point
I think you'll like it -- I usually go for a +/- 30 degree groove (i.e. two cuts to form a triangular wedge) with a ~45 negative rake angle, if that makes sense. I also built a little finger grip out of FR4 that slips over the knife since it's a bit on the narrow side. When soldering to large ground planes (as you are in this post), I've found it's quite handy to quickly cut 3 grooves around the intended location as a thermal relief--makes the soldering much easier.
oshpark wrote 01/10/2017 at 00:06 point
We appreciated how much you love soldering after listening to the last The Amp Hour episode :)
Ted Yapo wrote 01/10/2017 at 00:53 point
Thanks for the tips; I'll try that.
I bought a pair of cut resistant gloves to try also (on the non-dominant hand).  We had a blender incident here last month that resulted in nine stitches to my better half's left index finger, and it has made me reconsider all the blades we use.
Yann Guidon / YGDES wrote 01/08/2017 at 19:23 point
copy-paste from the original thread: https://hackaday.io/project/18868-improbable-secret-project/log/50780-open-collector-fail-the-atx-power-switch-saga-continues/discussion-73557
____________
such thing could be called "LVDCTL" : Low-Voltage Direct Coupled Transistor Logic.
I can suppose it hasn't been implemented for several reasons such as :
- poor noise immunity
- those base currents that can't be controlled
- transistors were too leaky and inconsistent performance, binning would be a nightmare
- it's better to have one reference than two, less confusion and better bargaining power when ordering 1M parts
- maybe it's not as fast as other topologies
____________
now it seems that Baker used resistors to control the base current, which I think is a good idea(tm)
Yann Guidon / YGDES wrote 01/08/2017 at 17:24 point
Do you remember that PDF that @esot.eric sent about DCT ?
https://www.computer.org/csdl/proceedings/afips/1958/5052/00/50520022.pdf
Well, scroll to the LAST page and there you have it !
Unfortunately only the first page, with the diagram, is available...
Ted Yapo wrote 01/08/2017 at 17:31 point
Yes!  I didn't see it there before.  Maybe we can find the other pages somewhere
The R.H. Baker who wrote that article is the same Baker from the Baker clamp circuit(s) I've enjoyed playing with.
Yann Guidon / YGDES wrote 01/08/2017 at 17:35 point
yes, saturation will be an ennemy to combat :-D
Yann Guidon / YGDES wrote 01/08/2017 at 17:39 point
Eric Hertz wrote 01/09/2017 at 03:32 point
hah! How'd I miss that?
Yann Guidon / YGDES wrote 01/08/2017 at 17:18 point
I'm sure a better performance can be obtained by adding ideas from nonsaturating current steering circuits. The current and voltage are probably too high, adding a resistor in series should probably make it a bit faster (along with a capacitor in parallel)
Yann Guidon / YGDES wrote 01/08/2017 at 17:16 point
Well, from the point of view of your first try, it works :-D
Now the challenge is to make a MUX.
