This hackaday description shows I I build a full passive DIY NAS with 3x2.5GBE and >=2x4TB SSDs ("brother") to be used with its companion 2x1GBE,2x4TB SSDs (little sister) as multi home redundant cloud storage. This hayckaday describes the hardware build, the software setup can be found here (upcomming).
Please find an overview of teh components in the description andthe detailed build inside the logs.
| PC Component | Selection | ~Price (12/2023) |
| CPU+Mainboard | CPU+Board: CWWK j6413 32GB RAM: CT2K16G4SFRA32A | 175€ 80€ |
| Storage | boot: Crucial P3 500GB M.2 PCIe Gen3 NVMe
system: Crucial P3 1000GB M.2 PCIe Gen3 NVMe storage: 2x Samsung 870 QVO 4TB | 30€
60€ 360€ |
| Supply | PSU: Inter-Tech 88882190 (200 W, 20-polig, ATX)
Power Supply: Leicke 150W, 12V, 12.5A | 36€ 40€ |
| Misc | Power Buttons: Sata Cables: | 4€ 5€ |
| Total: | 790€ |
And this is how it looks when it arrives:
| Housing Componet | ~Costs (12/2023) |
| Cooler ALU (300x200x50mm), eBay | 30€ |
| 3x pulsating heat pipe (QY-SHP-D6-200SA/6MM 200mm long) | 24€ |
| Copper Block: 2* 50x50x8mm
Copper Bar: 12x6mm, 400mm Alluminium Bar: 2*300x10x5mm | 23€
16€ 5€ |
| 2x Thermal Paste (MX4, 4g) | 8€ |
| Plexi Glas cover (300x200mm, 8mm) | scrap |
| 4x10cm Bosch Profiles 20x20mm (scrap) | scap |
| Screws | scrap |
| Wood (6mm, ~0.1m²) | scrap |
| Total | ~130€ |
And this is how the hardware bulk looks like:
And after several build ours the beatifull result looks like this for a total cost of about 930€ (and ~100€ shipment costs, wrong orders and so on ...)
- Full passive and no moving parts, <40°C under load
- Box volume: 30x20x15cm + power supply
- Performance values:
- 12th Gen Intel Celeron 4core/4thread 1.6/3.0GHz CPU @10Watt TDP
- 4TB mirrored SD storage, 1GB application store
- 3x 2.5GBIT Ethernet
- 32GB RAM
- 930€ and a lot of build fun!
For the little sister see the last project log.
BastelBaus
The Big One
Jonathan Kinnard
